The past few months, I’ve had no time for modeling due to a lot of “real life” obligations. I’m finally starting to get a little bit of time, and have used it for a couple of upgrade projects on my 1/24th scale In-ko-pah Railroad…
First off, i converted my kitbashed, narrow gauge RS-3 to use battery power. With all the electronics inside the hood, there was no room to put the battery in the loco. Besides, I prefer to charge lithium batteries outside of any irreplaceable models, in case something goes wrong. So I turned one of my old gondolas into a battery car.
To hide the battery pack, I made a false load of scrap iron, starting with a basic box made from Sintra PVC foam board. Then I covered the top of it with broken and twisted bits of styrene shapes and strips – a good way to use up some cutoffs. I sprayed it with a coat of red primer, then black primer.
Then I used Sophisticated Finishes brand “Instant Iron” and “Instant Rust”, and finished it off with a few touches of acrylic to look like old paint on a few of the parts:
My next upgrade project was replacing the lights in my structures with LEDs. Originally I used grain-of-rice bulbs, which are cheap, easy to use, and fit into even very small scale fixtures. Unfortunately they keep dying on me, rather mysteriously and inconsistently. Some have lasted for years, others need almost constant replacing.
I’m getting LEDs in several sizes from this source:
http://www.modeltrainsoftware.com/bl-212.html
If you want to see how I installed some of them, go here:
