Iʻm building my first HO layout using Peco track and I need to fine the right curved turnouts for it. Two are switching in from a 24" radius to a 22" radius and one switching out from a 22" radius to a 24" radius. Most likely all 3 are the same except for left and right switching. What and where can I find these electrofrog curved turnouts? What are my options?
No curved turnout matches a true curve exactly because of the points and frog. So you can’t “drop-in” a curved turnout and have it fit exactly in a 24" radius curve, if that’s what you are trying to do.
Instead, you would need to design the the track plan around the curved turnout. This would be easiest with flex track.
I’ve listed the code 83 Peco curved turnout specs, and they appear to be way out of what you are listing.
But if you don’t have to have Peco 100%, I see Walthers code 83 curved #6 on fleabay.
Walthers #6 curved are nomially 24" outer and 20" inner radius. People have reported measuring the inner is really a bit less, closer to 19 or less inches.
Basically the point is Walthers curved turnouts have inner and outer radii that a much closer together, nominally 4" apart. Peco, OTOH, have inner/outer radii which are much more different, such as the code 83 #7 curved (outer 60", inner 36"), which is way-off from what you are trying for.
RE: Walthers #6 curved, it appears it is referred to as #6 1/2 curved but the specs seem to be same, 24 outer, 20 inner (nominal).
The Walthers #7 should be nominal 28 outer and 24 inner radius if that is also useeful.
For what it’s worth, Walthers has manufactured turnouts listed somethings as DC type but around 15-20 years ago, they retooled and offered what they labeled as DCC friendly versions. They have the frog isolated and the point rails are isolated from each other. If you run DCC, that may be useful for you. OTOH, some DCC hobbyists have reported using the older “DC” versions on DCC layouts with no issues.
There is no reason you shouldn’t be able to use non-Peco turnouts if they fit the need. I mix brands where needed and have no issues.
There is also the Fast Tracks build it yourself option! All you need is a copy of a scale drawing (don’t use the original) of whatever custom turnout you need to build, glue the PC ties directly to the drawing copy, then shape, lay and solder your rails using an NMRA track gauge. I have done this with curved turnouts, wyes, and constant radius diverging route turnouts (to enter/exit a helix). It takes a little patience but is not all that difficult. Better yet, your rolling stock will roll through these turnouts better than they do through commercially made turnouts. Best yet, when someone points to your turnout and asks, “Who makes that?”, your answer will be, “I do!”
As RioGrande mentioned, the Walthers curved turnout is your best bet for a drop in fit, then you will need to adjust the tracks around it to fit.
I believe Walthers used to make these electrofrog, in the days before DCC was common, but I’m not sure. If so, they would probably only be available on ebay or something similar.
Currently produced product, which is much easier to find, is insulfrog, known as “For DCC or DC” on the Walthers packaging.
If you can find a “DCC” ready version of the Walthers #6 curved, it will be the easiest to wire.
I believe the effect will be basically the same as the Peco electrofrog if you energize the frog - polarity can be controlled using an appropriate switch machine support that.
All of Walthers DC turnouts were similar to the Peco electrofrog - they had solid metal rail from the end right through to the frog. The DCC friendly versions still have a metal frog - but it is isolated as are the point rails from each other. The frog an still be made “live” or electrofrog as long as it is wired that way.
For what it’s worth, I am planning to use mostly Peco electrofrog turnouts on my next layout, but in a few cases, I will be using DCC friendly Walthers #8 curve turnouts in places where the geometry fits best. I bought two of them last spring before the #8 curved Walthers DCC ready became much more difficult to find.
The Walthers/Shinohara code 83 curved turnouts have curves that differ by 6, not 4. The larger curves are stated correctly. And the radii are true through the turnout. Trust me-I have many.
Yep, which is why I labeled the radius in my posts as “nominal”.
It is generally known the inner radius is smaller than is labeled, although figures reported seem to vary depending on who measures it. I haven’t found the mis-reported inner radius to be an issue with fitting the turnouts into layouts I have designed an built in two past occasions either. It seems to be somewhat more of an academic thing.
The salient point here to the OP, kenben, is Walthers offered curved turnouts which are closest to his needs, and they can still be found on the secondary market.
I decided to run a Walthers 948-8826 Curved Turnout up on my CAD just for kicks. The picture below is what I came up with using the Walthers picture from their web site and should be accurate within a 1/16”.
The inside curve radius is 24”(red curved line) to the point of the Frog, by canging the inside curve center to full length it changes to 26” between the Frog and the end of the rails.
The outside radius is a constant 36” (green curved line).
I didn’t measure the actual center at the frog but by eyeball it’s not off more than 1/32” at the frog for 24” radius from the points. The curve radius changes between the frog and the end of the rails. The outside radius is true from rail end to rail end.
EDIT:
I went back to my drawing and I missed it by eyeball. The track center line measures .038" toward the outside rail at the frog point.
I suggest you find, and make fit, Walthers/Shinohara #7 curved turnouts. Look for the new “DCC Friendly” versions.
I have used, and intend to use, #7 W/S turnouts with no problems up to heavy 4-8-2 locomotives. The radius measurements of these turnouts are pretty close to what you want. They should fit with your DCC wiring scheme just fine.
Well guys you can’t go by my CAD drawings for the correct radii of Walthers curved turnouts. While I was doing some further checking of other Walthers pictures I discovered they don’t necessarily use the correct pictures in their advertising pages.
I found three pictures of the 948-8826 turnout, all with the same part number, all are different sizes.
I laid out one of them to compare and it measures inside radius (diversion) 17” with the outside radius (non diversion) 24”. This turnout has perfect radius on both tracks.
To get the correct scale dimensions for my drawings I use the between the rails measurement for HO (.6605” NMRA) as reference and go from there. That is the only reference that always remains the same on all HO track.
The pictures are different when overlaid but look like the same turnout. I guess the advertisers don’t always use the correct pictures, just close enough to sell. If they don’t Photoshop their pictures they sell a 17” x 24” curved turnout under some
