Inch scale, considered garden?
Ok, I may be in the wrong forum here, but here goes[:o)]
I am in the process of building a inch scale GP-40 (ish) battery powered, with a potential of being the beginning of an outdoor empire.
Here’s my stupid (possably newbie to outdoor) question.
Are there any inch scalers in here?
What hazards are there for battery operation (four motors, in the trucks, chain drive to the wheels)?
Is there rail available, or do I need to fabricate my own? (I’m considering using inverted T steel stock, bolted to 2x4 pressure treated lumber, or possably that recycled “milk jug” Trex trade name stuff)
Any input would be apperciated.
There are no stupid questions; only ignorant by-standers.
I cannot discuss this 1" business this is a metric country and we are not allowed to have non metric conversations nor are we allowed to make non metric statements.
ie; give him a centimetre and he’ll take a kilometre just doesn’t sound the same.
Rgds ian
So far, I haven’t heard of anyone here doing 1" scale. There is a company that sells track and equipment for that scale, Riding Railkits (www.ridingrailkits.com). They might be able to help you out.
Like Ray said, check out that site, everything for 1" scale! Also, Talk to my good friend Greg Robinson, editor of the Grand Scales Quarterly and the 7+ Railroader. His e-mail is mainline@sunset.com
Hi tsgt Bob
The size of train you are working on means you have entered the
Model Engineering Zone [:D]
Not realy the right forum for that, however some one makes rail and fish plates for that size and probably does dog spikes as well
probably riding rail kits as Ray sugests
As an alternative you could use flat bar (No idea of what would be an apropriate size) welded to steel tie plates to form what looks like track with very thin and small sleepers.
Which is then screwed to wooden (Or plastic/concrete) sleepers with a screw each end of the tie plate.
But you would need a jig made so you could make reasonable lengths at a time say the std purchase length of the flat bar used for the rail
The jig should be made so it can make straight and curved track also with a change of bits make points and crossings.
all to the same stds every time if the jig is made properly and might be cheaper in the long run than comercialy made track componants.
Good luck in your venture.
I hope you will excuse me while I just go and turn green with envy[swg]
regards John
Sounds cool.
I don’t know of anybody else doing 1/12 (Ian, you can still talk fractions down under without breaking any laws[:-,]) 1/8 scale, 1 1/2 is a popular scale. Long ago I designed a railroad at 2 inch to the foot, but never got to build it.
For your track, do a google search for “Groovy track.”
Torby mate;
I guess i can talk fractions but no one seems to do it any more; you want dob me in to the Australian Metrification Board will you?
Rgds Ian
Did you know for a long time after metrification; people used to illegally import imperial rulers from New Zealand; but they stopped that New Zealand went metric as well and where they go the rulers from i do not know.
That bit about about sayings what about in for a cent in for a dollar or even 450 grams.
Dangerous contraband there
Thomas the phrase should read: “in for a (pre-decimalisation denaria equivalent) in for a (pre Wilson devaluation (this will not affect the pound in your pocket) pound (sterling))”
Alternatively: in for a (sanitry tax coin) in for a 1/2240th of an imperial ton…
Excuse me -my son wants to know when I am going to saw the head off the Giraffe!!!
regards
ralph
What about a stitch in time saves ten, thats metric for sure.
I hope your giraffe stands still long enough for you.
Where is the Peak district, i have been to the UK recently and i have been pretty well all over!
Rgds ian
Rgds ian
It is generally accepted that the peak district begins at Derby and extends between Manchester and Sheffield. It is some of the most beautiful and deadly countryside in England…
Have a look: http://www.visitpeakdistrict.com/
regards
ralph
PS Surgury on the Giraffe went well. I am building a replica of Hornby R348 -but in 16mm scale. Hence the need for the Giraffe head.
Hi ralph
I used to have the Triang one
details details pictures on the scratch build forun please
regards John
What gauge or scale is considered “garden” for this forum. My guess is everything run in the garden from small gauge/scale up to but not including small trains people ride on. Would that be close to correct?
If it goes on rails it suits the forum, though most of us build for 45mm gauge.
Thanks everyone, the info was, as ususal for these forums great.
Sorry!
Mylanta works for that![:p]
I have had this in mind since I was 10 years old, and I have been collecting the parts for the locomotive for the past 5 years or so.
It won’t be an exact “rivet counter” style model, but more of an outline of something that looks like a locomotive. I have fabricated the trucks, using high torque motors to each wheelset, sideframes are 1 inch square tubing, ball bearing blocks bolted to this for the wheel supports, bolster is a fabricated piece of 1X2 steel etc…
Get the idea?
I had tried G gauge in the backyard a few years ago, freeze and heave did nasty stuff to my roadbed, and The Better 9/10s wanted more of “her” patio for flowers (yeucccccch)
Bob
Back to your question, I’d say NO. ride on trains is a whole different aspect and thinking to the hobby.
I looked into it before “G”. but found I could do more with G in the modern mainline types than in 1".
I have been into G for 14 yrs and no problems with the concrete roadbed.
The last thought around here there is even fewer folks who ride on than g.
gets kinda lonely arund these parts[;)]
You could call it 1:12 scale and be done.[^][^][:)][:)]
Hi FG& J
I would say you got it in one.
tsgbob is working on the smallest of the ride on trains.
would still be nice to see what he is up to.
After I have taken that Mylanta Bob sugested[:D]
regards John
I designed one in 1:6 to build with my boys. Switched to G when I found myself in the asylum[8]
