Im current working on a layout with 2 mainlines with reversing loops. shelf lay out with aproximately 110 feet return. my question is does any one know a simple formula to scale in ho how many scale [xx(]feet are in an inch? and how many inches would it take to create a mile? [banghead]
10.5’ x 15’ = 913.5’ (HO) x 1305’ = 1,192,117.5 sq. ft. in HO
1 acre, not ‘acher’ = 43,560 sq. ft.
1,192,117.5 / 43,560 (acre) = 27.37 acres in your room.
Tex,
Fistmele and smoots are measurements of distance not area. You may be confusing fistmele with acres, since its a measurement used in relation to bows, hence the connection to archer.
I know that! That is almost in the duh category. Any unit of distance can easily be converted to area.
No I’m not, I missread what he said to be archers - not acres (yesh now I can’t even spell it right), so I just assumed he was trying to be anachronistic and arcane. I played along.
Side note - the importance of proper spelling so people don’t have to interpret what one writes.
Side note 2 to Bergie. Please add a spell check to the forum software.
I know this is off topic and irrelevant, but I figured that it would take at least ten 40’ shipping containers end to end and at least two wide to house a scale prototype UP Bailey Yard North Platte.
What a refreshing discussion. I thought it was about the time someone would ask how you convert inchs to feet or how you figure a grade percentage again.
Let us begin with a constant which I memorized many, many years ago.
HO is a scale 3.5 millimeters equals one foot. A millimeter is .03937 inches. 3,5 millimeters times .03937 equal .137795 inches which is the constant for an HO foot.
To find how many (HO) feet there are in one inch you need to divide 1 by this .137795 constant. There is, however, an easier way: if you have a calculator - and who of us doesn’t? - you have a key on the face of that calculator marked “1/X” - I have never encountered a recent calculator which did not have it. This is the inversion key which automatically divides 1 by the number in the register. So, insert the constant .137795 into the register and hit that “1/X” key and you will come up with 7.26 - actually it is 7.257 - in the register. That is the number of feet in one inch. If you multiply that by 12 you will come up with 87.086 and that is the number of (HO) feet in one (actual) foot which is the HO ratio. Invert that number with the “1/X” key and multiply the amount in the register by 5280 feet and you will get 60.63 which is the number of (HO) feet in one (actual) mile.
Subtract 60 and multiply the remainder by twelve which will give you 7.56; The result of all this is that you have now computed that one (HO) mile is 60 feet, 7.56 inches.
