new to g-scale. I am curently putting in a 25x60 indoor around the celing pike. It will be two seperate loops.
imjust about ready to purchase engines and power supply. Id like to have a few questions answered.
1- who makes a good transformer, Id like to run two diesel engines with sound on one loop and a single steam engine on the other. i dont need to have a hand held controler, and can i run a lash up without dcc.
2- what is a good size wire for bus wires and feeders
On my first layout 10’x20’ I used an LGB 1amp powerpack and light guage doorbell wiring to run it worked fine, now I am smaller but using 18ga wiring similar to the wiring used for outdoor low voltage wiring systems, some parts are even using speaker wiring. (I’m still only using a 1 amp pack) but your size I wouldn’t go for less than 10 amps, and 16-18 ga wiring.
