install problems for BNSF 8010
I just downloaded 8010 off of the MSTS web site and it downloaded perfectly then when I got off the internet the icon was not there I serch every where and nothing dose any one know what happened?? what should I do??
kevin
it now happened again except it was a chessie system download from www.alabamarailfan.com is there anything that I can do
kevin
To where are you saving it? The easiest thing to do is to create a new folder on your desktop and then save it to there. Then you know where to look for it when you install it.
Isn’t 8010 a standard SD40-2?
You need to save it to a temp file and then install it from there. I don’t know where you saved it to when you downloaded it, but it is there waiting for you. I suppose you could search the drive for it…
After extracting the file, move it to your trainset file. It should work.
nevermind I got it to work a few days later.
kevin
