I have developed a relatively easy method of mounting the Tortoise Switch Machines on my layout and thought I would share it with others. It may be easier than other methods and any suggestions would be appreciated. So far I have installed about 20 Tortoise machines this way. I hope this helps some that have this task ahead of them, it really is an easy system to use without having to try to get those little screws to hold the Tortoise upside down under the layout.
- Cut mounting plate from ½” plywood approximately 3” x 5” and drill a series of holes for the two mounting screws (1 1/8” deck screw) and clearance for the throw wire (5/8” dia.). Once you have the first one laid out it is easier to make a batch of them at one time. I made 24 the first time.
- I also made a drill template for the Tortoise screw pattern and drill pilot holes for #4 x ½’ binding head screws (I used sheet metal screws from Home Depot). This is made of 1/8” acrylic and is shown in the second photo.
- Mount the Tortoise Machine to the mounting plate.
