Recently, at a local auction, my dad and i acquired several brass locomotives at dirt-cheap prices (mostly Overland, but some Pacific Pike), including several CN GP40-2W’s and M420W’s, a CN GP9RM, and a beautifully painted CN C44-9WL (it’s worth near $1000, and it sold for $45). Unfortunately, it seems that a talented modeler passed away, and the family had no idea what his collection was worth. We did, and made off like bandits, as there was only one other serious bidder.
Anyway, it leaves us with a decent number of brass locomotives that will eventually be equipped with DCC decoders. A local hobby shop has a service that they will install the decoder for you, and i was discussing this with one of their employees. He said that the brass shell has to be isolated from the rest of the locomotive for dcc operation. It brought me to wonder: is this actually true, and if so, how is this done? Also, what other modifications must be done to a brass diesel for dcc operations?
The shell is no problem. Neither is the motor frame unless one brush has been irreversibly grounded to it. The only things that absolutely, positively must be isolated are the motor brushes.
One brush is already isolated. Isolating the other might require breaking a solder joint or slipping a bit of insulating tubing (stripped from a wire) over the bare side of the wishbone spring on an open-frame motor.
For safety’s sake, there should be a layer of insulation between the decoder and anything metal that could be connected to a rail. A strip of vinyl electrical tape is all that it takes.
Typically, the frame, and everything attached to it, is ‘hot’. The motor is connected directly to the frame, making wiring easier.
The tender is also hot, and functions as the return for the motor current. It is the opposite polarity of the locomotive chassis. It is isolated from the locomotive, and a wire from the motor connects to it to complete the circuit.
You should also measure the stall current of the loco motor before taking anything apart. This will let you know what amp rating the decoder needs to be, or if the motor needs to be replaced. Just put the current meter (Multimeter) in series with one wire of the DC test power pack and the track the loco is being tested on.
