Installing LokSound decoder in Spectrum 44 tonner
I am attempting to install a LokSound Micro decoder in a Spectrum 44 Tonner. My question is this. Would it be better to scrap the existing “board” and “hard wire” the decoder? If I did that, it would provide more space for the speaker (in the cab). Are there any pitfalls I should be aware of? Thanks for any help anyone can give me.
TRNJ
P.S. The decoder is programmed for twin Caterpillar engines!
I have not installed a decoder in my 44 ton yet. If you stay with the board, cut the capacitors off the PC board. All depends on the available space.
The below link has a little info about the 44 ton.
http://www.tonystrains.com/download/PopLocosFlaws.pdf
No need to remove the old board. Just make a baffel that will fit the little speaker, paint it black and shove it into the cab.
David B
