insulfrog vs electrofrog
Ive just purchased 10 peco points have i made the right decision by going with electrofrog or should i have purchased insulfrog [*-)]
They are different for people with different needs. What are your needs that would make either one a problem for you?
IOW, we can’t really address your concerns without understanding your needs or limitations.
Electrofrog is far better for no sure footed electrical locomotives like small engine with two or three axles (small steam).
They allow to have constant electrical continuity in all the turnout track.
Even with sure footed locomotives it’s better to use them, as far I’m concerned; we never have enough “good contacts” for our locomotives.
A live frog is the best we can do with a frog.
Since I’m a big believer in (electrically) powered frogs, I think you made the right choice. But they ARE harder to install. So you need to decide if you’re up for the more difficult installation or not.
I suggest you do a search for “wiring peco electrofrogs” and see what you think.
There’s no point in people here repeating what’s readily available already online. Unless they want to.
Ed
Sorry for the lack off information my appologies,im attempting to build my first layout as an industrial switching layout,from what i have read electrofrog may be better suited to slow moving loco’s, now that may be a matter off opinion or a proven fact,but my first port off call is always this forum so any feedback is greatlly appreciated[bow]
More info is always better. Well, almost always.
Oh, it’s a proven fact, all right.
Some might argue that it is not SIGNIFICANTLY better. For their purposes. Can’t argue with that. On the other hand, it’s awfully difficult to argue that a blob of plastic or dead rail is going to deliver electricity to a driving wheel.
All of my track switches are live (electro-) frog. All of the track switches I will ever own will be live frog. The ONLY reason I can think of for using insulfrog is to make wiring easier. Once you figure out how to wire a frog, THAT reason is gone.
Ed
It’s been a while since I’ve bought any PECO turnouts, but their wiring diagram instructions are pretty straightforward.
As someone with 40+ Atlas insulated turnouts and (if you see the other thread) figuring out ways to get the point rail to have good electrical contact, I would say I am definitely in the electrofrog camp now. Whatever switch machine (even manual ones) you use can be bought with capability to switch frog polarity.
NP
I don’t have Pecos, rather Walthers-Shinohara code 83, so I can’t help much. I was going DCC and did not want to have to modify later, so I wired my metal frogs, in this case the correct frog polarity provided by contacts on my Tortoise switch machines. I wonder if it makes a difference if you will be strictly DC or (now or eventually) DCC with the different Pecos, not just in performance but also in how they might be wired for best performance. If that makes a difference regarding how to wire the two types, I’d do some more reading or inquiry (maybe folks here can clarify concisely) before opening the packages and eliminating return possibilities.
A google or two on prior threads may help. Example:
https://www.google.com/search?ei=FlQTWtuXB8rjjwTHnZyQDA&q=site%3A+cs.trains+insulfrog+vs+electrofrog&oq=site%3A+cs.trains+insulfrog+vs+electrofrog&gs_l=psy-ab.3..35i39k1.10008.12373.0.14010.6.6.0.0.0.0.113.615.3j3.6.0..2..0...1.1.64.psy-ab..0.4.414....0.i2iaAaLnJl0
And there are detailed sites that get into the nitty gritty also. I’ve not digested it enough to guide your interests. I would not plow ahead until understanding what I would want to achieve and what it takes to do that, but that’s just me. I wouldn’t want hindsight on this after it was all installed…time, effort, $$.
https://www.peco-uk.com/page.asp?id=instruct
http://www.wiringfordcc.com/switches_peco.htm
http://www.dccwiki.com/PECO_Electrofrog
I only have electrically isolated frogs on my layouts. I use hand-laid ones, Walthers/Shinohara, and Peco Streamline Code 83 Insulfrogs. I don’t have any stalls on mine unless we’re talking about a small SWX switcher or something like a tank 0-4-0. Steamers with tenders and longer diesels just don’t give me any problems.
I don’t think a person can make a mistake these days except with the wiring if they are electro-frog. If the frog is ever energized, it needs to reliably conform with the polarity or phase of the rest of the tires on that side of the loco’s phase or polarity. Failure to switch it when needed means you’ll get a stall due to a short, and possibly some real damage. So, no need to regret your choice…not yet. Just heed those who caution you about making sure you have it firmly in your head how your’e going to feed the frog the right phase/polarity at the right time.
Reliable turnout wiring is the same for DCC or DC. Peco Electrofrogs are easy to make bulletproof - the newer ones have gaps in the ties underneath where you need to cut existing jumpers and add new ones for absolute bulletproof reliability.
Older Walthers/Shinohara turnouts, the ones NOT marked “DCC Friendly” have the same problem in DC as they do in DCC, if you use a Tortoise machine to control the frog polarity, you better have it pretty darn near dead on centered, because of the contacts change before the points have moved off the stock rails, you get a short. The gap in the Tortoise contacts is very small - this issue spawned a number of “how to modify a Tortoise” articles on cutting some of the copper off the board to make the gap bigger.
I thought I recall reading that one would NOT want to have the electro-frog turnouts if they planned to use DCC. I think it was a question of shorting, and that can be damaging with big currents utilized by DCC. ??
What size are the turnouts you purchased,…small, med, or large?
I was just going thru a number of turnouts I have collected for doing a layout, and discovered that the small Pecos are smaller than the Atlas #4’s I wassurprised! It appears as though the ‘medium Peco’s’ are equivalant to the Atlas #4’s, and the large Peco’s are equivalant to the Atlas #6’s.
If thats so. then how useful are the ‘small Pecos’ if the common knowledge is not to use turnouts less than #4’s ??
N way, Electrofrogs are most definitely superior, especially when running at slow speeds. Insulfrogs can have a problem where if a wheel si slightly wider than spec, it will short at the point of the frog. The common solution is to make the insualted part longer with nail polish or similar, but that will wear off and need to be replaced periodically. Electrofrogs have no such problem, especially when modified per the instructions shown on Wiring for DCC. But, they can be used straight out of the package if the frogs are powered via an electronic reverser like the Frog Juicers from Tam Valley. I’m still modifying all mine, BEFORE installing them.
Sort of the same argument for the current capacity of Tortoise contacts - how many locos can actually occupy a single turnout frog? Be REAL tough to get more than one. So maximum current would be no more than 1 locos’s worth, hardly a problem. And if you use switchmachine contacts, you would normally line the turnout BEFORE the train gets there, meaning it’s switching 0 current.
Properly set up, there are no dead spots and no hinged areas of an Electrofrog to carry power - it’s all wires or solid piece of rail.
So it’s basically a case of getting the wiring correct and your laughing.You mentioned frog juicers so if i purchase a frog juicer for each turnout would that simplyfy the wirining process.
It can, because there’s no case of getting the contacts backwards and instead of preventing a short, causing one each time. But that’s only for DCC, the Frog Juicers do not work on DC.
Also, it’s not an inexpensive proposition, vs taking a little bit of time to just wire things correctly. I’d save the Frog Juicer for complex trackwork where it’s difficult to figure out what piece should be what polarity for a given condition.
The Peco instructions show where to change the jumpers for the ultimate in reliability. It’s not difficult, but you do need to know how to solder and you need a fairly fine tip on your soldering iron to get into the space without melting ties. It’s well worth the effort, especially for a slow speed switching layout, and by making this effort and having the turnouts totally reliable electrically, there’s no reason to spend money and put keep alives in every loco. A properly wired Electroforg has no spots where there isn;t a rail with power touching the wheels of even the smallest loco.
Thanks for that so i basically just need the point motor and switch for each turnout.
Yes, Peco has a switch that works with their style point motors, or you can use something like the Tortoise which has the switch contacts built in.
Not necessarily. There are mechanical switch controllers that have electrical contacts for the frog. Bullfrog, Blue Point and one of the caboose Industries ground throws.
This is an important point. I went to the trouble of wiring my Walthers-Shinohara frogs (with Tortoise contact switching) for my DCC layout and would do it again. The hard part is figuring out up front how to wire a given turnout for what you want to achieve, including reduced probability of interruptions, especially for DCC sound locos. Regardng locos and my track installation, I have found that maybe 10% of my DCC sound locos warrant a Keep Alive (or similar). My first indication is sound “hiccups” from a short connectivity disruption. Usually it is time to better clean my track with the CMX car (another thread). But the remaining problems (with cleanest track) include a Genesis GP-9 traversing my not so smooth triple 90-degree crossings (with short, soldered rails for desired track centers), a Bachmann doodlebug with converted power truck, etc. So those received added capacitors. The point being, if one does a near max job on ensuring track power, only a few locos in a broad roster might still need Keep Alives. It’s more than just short wheelbase locos, as some bigger ones may have unique issues with relationship to your trackwork. So, I’d power the frogs for DCC sound, for sure, as once you learn how to wire them for initial install, it becomes routine to install them that way.
Another angle. For my W-S turnouts I did wire the frogs. But I did not take the final step (for that type) to jumper
