Is a caboose or shoving platform necessary for one low car such as an empty flatcar or gondola? (Without someone riding the car)
I ask this because I have one particular switching location that has both a facing and trailing point spur fairly near each other, and this would never have more than one car ahead of the engine if I switch it out that way. Otherwise it would require a long run around, or more likely I would just service it with another train from the other direction, but I would prefer not to do that for scheduling reasons.
Early 1970’s there would be a caboose on a local (not a “shoving platform”).
The question is how far are you shoving it? 50 ft? 1/4 mile? 5 miles? Current agreements (which were not necessarily in effect in the 1970’s) say a shoving platform is required if the move is over 1 mile. It almost sounds like you are making the train up out of the yard with a car, the engine, the rest of the train and the caboose. Technically, trains shoving cars tend to be speed restricted (5-10 mph) and would have to stop at road crossings to flag them, unless they had gates or flashers (your rules may vary). A 1970’s local or yard crew will have an engineer, conductor, at least 2 brakemen and maybe a fireman and another brakeman.
Flatcars are almost impossible to ride, no place to hold onto.
Also, it is dependent on the weight restriction for the roadbed/tracks/rails. If you need to ‘reach’ into the yard or siding further than just the length+ of a single car, but are not to make the tracks bear the weight of the pusher, then an intermediate car or more is going to be necessary. IOW, the overweight item will need more reaching units between it and the car(s) to be placed depending on how far into that trackage the car is to rest. A caboose might suffice for a siding only 80 feet long beyond the frog to get a single car up nice 'n tight to where it needs to be. Why it would be a caboose, though, is an oddity for me. Maybe some rails will speak up and enlighten us.
Forget the term “shoving platform”, I think that is incorrect and/or misleading in this case.
This particular run is a “very local” local that only serves a set of team tracks, a scrapyard, and a coal dealer, just outside the main yard limits. The coal dealer is served with a low gondola that is unloaded by hand and winch, and has no weight restrictions on the spur.
This train would only have a handful of cars at any given time and the one facing point spur for the coal dealer would be much easier if it could be tacked on the front of the engine when picking it up or setting it out rather than making a runaround and keeping it there all the way back to the main yard. I often do this now, and we are only talking a short distance, let’s say an imaginary mile, more like a couple feet in reality, before it gets back into the yard limits. Just not sure of prototype practice or regulations in a case like this and would like to know the proper procedure.
First you will have a 4 men crew so a caboose is needed for the conductor and rear brakeman.
Second you will need to protect your shove and the caboose will provide a whistle for crossings and a safe place for your rear brakeman to stand while protecting your shove.
There are speed restrictions for trains shoving cars.
Unless there are automated crossing warning devices (gates or flashers) a train shoving cars has to stop and flag the crossings.
Somebody has to ride the leading end of the car being shoved if there are any crossings or switches the train has to cross or come up to.
Those are basically the rules.
There is nothing prohibiting shoving a car, the train will have to get a “double air test” of sorts because it has to make sure it has air brakes on both ends.
Many crews would pull the car out and drop it by, especially in the 1970’s or earlier.
Yes, the train has a caboose. So the simple answer to the question appears to be that, yes, even for one car you need a caboose out front or someone riding the car.
Then should I have two cabooses as I still need it on the rear with all the going toward and backing up, right?
Nah you just need the one caboose. I’m pretty sure they would cut the caboose off on the mainline and have a flagman to protect it. After dropping off the car to be spotted, they’d pick up the caboose and continue on their trip.
If a train had more than one caboose it was usually because one was a Drover’s caboose on a livestock train hauling a crew of cowhands to help with loading and unloading livestock. Another case for multiple cabooses on a train would be a particular yard accumulated too many cabooses from elsewhere and was sending them back to where they’re needed. Only the last caboose would contain a working crew. The others would be empty and those crews would have rode back to their home terminal on a passenger train.
What the crew would probably do in most cases is drop the car by.
The train stops about 100 yard from the switch. We will assume the gon is right behind the engine. It uncouples the rear of the train from the gon to be dropped. They turn angle cocks on the engine and bleed off the air on the gon. The gon and the engine accelerate to about 4-5 mph.
If they are doing it by the book, the switch is lined for the spur. When they get to 4-5 mph the engineer backs off on the throttle, the slack runs in, the brakeman at the joint with the gon (rear engine platform) pulls the pin, the engineer opens up the throttle and accelerates away from the gon. The engine heads into the spur. As soon as the engine clears the points the brakeman lines the switch for the main track. The gon rolls by the switch. As soon as it is by the switch, the brakeman riding the gon sets a handbrake and stops the gon. The engine comes back out of the spur, couples into the gon and sets it into the spur.
Alternate if the crew wants to take a short cut. They drop the car into the spur and keep the engine on the main. They just better make sure the handbrake on the gon works and the spur is long enough to make sure they get stopped. If its a flat car, I’d drop two cars, the flat and a box or gon (or the caboose) to ride while setting the brake.
Having said all this, its quite possible that if its a short distance (a mile or less) with few or now grade crossings they might just shove it out there because that’s easy.
Another question is what happens after they spot the gon? Do they go back to the yard, do they continue on to the next location? How did they get to the industry, they are out of yard limits, are they on train orders, CTC or what?
By the way, yard limits really makes no difference to this question, Whatever the answer is outside yard limits will be the same answer inside yard limits.
We tested the handbrake before making a flying switch…You don’t need to shove the car at high speed just enough so it rolls at a safe speed-recall a man will need to uncouple the car and in my experiences the conductor would open the switch and after the wheels cleared the points he would close the switch…
First:
This is not a “Drop”. It is a “Swing”. A “Drop” is where gravity causes the car to roll/“drop” to the intended spot.
Second:
You don’t run the engine in the spur. That comes under the heading of “Double Switching”, creating more work than is necessary…doing things the hard way!
Which is what a good crew would have done to begin with!
From the late 1950s through the 1970s on a couple large eastern railroads: Most commonly the crew would just shove the car or even several cars back to the yard, even if a road crossing or two was involved. They might swing the car(s) by the engine, but usually wouldn’t bother. Wouldn’t matter if was a yard job or a local freight.
Yes, we used to have run around a string of cars at a siding, then we shoved them three miles to the plant and its facing point switch. An everyday move.
After the work was done, we “kicked” the cars up the main, ran the engine in the plant and let the cars “drop” back down to the cab.
dehusman
The train stops about 100 yard from the switch. We will assume the gon is right behind the engine. It uncouples the rear of the train from the gon to be dropped. They turn angle cocks on the engine and bleed off the air on the gon. The gon and the engine accelerate to about 4-5 mph. If they are doing it by the book, the switch is lined for the spur. When they get to 4-5 mph the engineer backs off on the throttle, the slack runs in, the brakeman at the joint with the gon (rear engine platform) pulls the pin, the engineer opens up the throttle and accelerates away from the gon. The engine heads into the spur. As soon as the engine clears the points the brakeman lines the switch for the main track. The gon rolls by the switch. As soon as it is by the switch, the brakeman riding the gon sets a handbrake and stops the gon. The engine comes back out of the spur, couples into the gon and sets it into the spur.
First:
Second:
Put a ball in your hand. Now, open your hand and what happens? Pure gravity takes over and the ball “Drops”!
Try getting that same ball up to the ceiling. You have to use force and “Swing” it or “Kick” it up there.
Maybe, you are living in the wrong neck of the woods. [;)]
Well, my 1968 Uniform Code rule book says this about dropping cars. “…and when dropping cars, know switches and brakes are working properly and run engine on straight track when practicable.” (The first couple of GCOR editions also said about the same. Back when the move was allowed.)
The Consolidated Code, and some that later adopted the CCOR, calls it a “running switch”. But, the CCOR also mentions kicking and dropping in other parts of the the book.
The Penn Central book I have says “flying switch”, the Conrail book says “running switch”. Both also have the same note, “also known as a drop of cars”.
Current GCOR says dropping cars is prohibited. However, “gravity switch” moves may be allowed at specifically authorized locations. In reality, the locations where gravity switch moves are allowed is getting pretty rare these days.
It’s probably just a local or regional thing. Crews in different areas used different terms. I’ve heard drop, swing by, roll by, fly by, flying switch, and several others, including one I can’t put on the forum.
1948 B&O Rulebook said Conductors “…will exercise good judgement in making running or flying switches…” I guess if anything went wrong he didn’t use good judgement?
The easiest thing to do is just shove the cars back to the yard and be done with it.
