I need to add a diode to each of my signals to allow current to only flow in one direction. In the past, I have bought diodes at Radio Shack, 1N4001 through 1N4004, depending upon which were currently in stock. The package simply referred to them as “diodes”. Now, however, some packages refer to them as “silicone diodes”. Other packages refer to them as “rectifier diodes”. Is this all one and the same or are silicone diodes different than rectifier diodes?
“Rectifier” it just means that its typical application is for rectifiers, but all generic diodes are rectifier diodes.
What is important is the PIV and maximum current. PIV is peak inverse voltage, specifying how much reverse voltage it can handle before failure. The diodes you bought have a PIV ranging from 50V up, so those diodes are more than adequate for your purposes.
The 1N914 type are fine for LEDs, since they can handle more than 10x the limit of an LED - the LED will pop long before the current dmaages the diode. They are also fine fooor controlling power to Tortoise switch machines, since those only draw about 18ma.
To rectify DCC, for installing a lighting circuit in a passenger car for example, it is recommended to use the 1N5400 series diodes - they can better handle the high speed switching of the power. The 1N4000 series are fine to rectify a 60Hz AC into DC, but DCC is a much higher frequency.
1N5400 series are rated for 3 amps. The last digit indicates the maximum reverse voltage it can stand. 0 = 50V, 1 = 100V, 2 = 200V, 4 = 400V, etc.
1N4000 series are rated for 1 amp, the last digit again indicates the maximum reverse voltage, but it’s not the same as the 1N5400. On the 1N4000 series, 1 = 50V, 2 = 100V, 3 = 200V, 4 = 400V.
Reverse voltage is the voltage across the didoe when the polarity is such that current does not flow through the diode. Most LEDs have a relatively low reverse voltage rating, which is why it is usually recommended to put to of them anti-parallel when used with DCC, which means the highest reverse voltage one LED will see is the forward voltage of the one that happens to be lighting up. Or use a standard diode if you don’t need two LEDs.
