I was trying to grind off a piece of Atlas flextrack when the grinding wheel caught an edge and tore up a 2" section of the “fixed” rail. The track is glued down and I don’t really like the idea of replacing such a short section.
Any ideas on how to replace the rail into the molded “spikes”?
Use a cut-off disk and remove the rail(s) length that is/are unsuitable. Use a grinding device to remove the spike heads molded to the rails just cleared. Use CA, white glue, Weld Bond (Canadian Tire), or even Goo to fix the rail section you replace. Once you weather the ties and paint the rails, no one will know the difference unless they look closely for the missing spike heads.
