Is the boxcar obsolete?
I see fewer and fewer boxcars every year…maybe not surprising in view of the ever increasing popularity of containers. Are the rails still selling boxcar service or is the boxcar being phased out?
There’s still plenty of boxcars, but there are a whole lot more containers…
I saw NS deliver 1 boxcar to a small factory in Maumee Ohio Friday. NS had a wide nose unit on the track also so they had to use a 4 axle unit to shove the boxcar and the dead wide nose unit place. The spur leading to the factory is used for engine space as well.
I guess it depends on your definition of box car. Traditional boxes with wheels attacheda re probably going to disappear with time. Containers are much more flexible and don’t require the shipper or receiver to have a siding and sidings are extremely expensive. My father had the job of building a new plant outside Philadelphia for his company back in the early 60’s. At that time the Reading wanted over $35,000 to install the trunout and signal it. Containers are much more flexible and could be considered box cars since they are boxes on wheels. They just aren’t the same in my opinion.
That’s interesting… I read somewhere that containers are not as fuel efficient given that they are transferred along with the load.
Boxcars don’t necessarily require sidings…the shipper can truck his load to the railhead where it is then transferred to a boxcar. Given that so much freight is palletized these days…this may be a better alternative to containers.
TTX/Railbox added a bunch of brand new 50’ FBOX and 60’ TBOX boxcars in recent years. So, I’d say boxccars aren’t going way yet.
As a general rule, containers are used for shipments from/to foreign ports, while boxcars are localized. As long as there are shipments that need to be protected from the weather and remain in North America, boxcars will still be necessary. I still see a lot of boxcars on the Union Pacific Sunset Route’s manifest freights.
Rail Runners are pretty efficient since they’re basically a trailer with two train axles and a pair of couplers. A lot of time (which actually DOES = $) is saved in the loading/unloading of the box car. Aluminum/wood/plastic trailers are pretty lite compared to steel/steel/steel box cars.
Does anyone remember the 40’ grain boxcars?
the local shortline on both on half of their twice daily trains has boxcars. many UP trains have boxcars( a lot of them are leasing)
PS- Helps to go to a school by the railroad
Boxcars are still used heavily in the pulp, paper and plywood industries. So, no boxcars are not obsolete.
Absolutely not! A close study of the big 6 will show you more boxcars of all types are handled then intermodal.
http://www.railroadpm.org/Performance%20Reports/NS.aspx
Several years ago NS converted excess box cars into container cars or trailer cars. There was an ad in Trains at the time. It said something like, “Last week it was a box car”.
How time has change.During the week of 10/10/08 NS handled 22,294 boxcars of all types versus 7,464 intermodal cars.
Only the CP and BNSF handled more intermodal then boxcars during the same week…
Yes but an intermodal car could be five sections long with as many as four containers per section as each section is a number followed by a -e. So one intermodal car could actually have five times four containers or twenty compared to one box car. So the theoretical limit of containers if each car were a five section one would be 20 x 7464 = 149,280 containers. Assuming half were empty that would 74,640 containers. That is more than three times the number of box cars. Now I don’t know how many containers equal the box car volume but it sure looks to me like containers are more prevalent and I doubt the railroad is going to let us know the actual numbers. If they are individual cars they can still handle two containers so my opinion (not a fact) is that containers are more common.
Well,You will have to prove that here along NS Sandusky line…1 in 10 trains are intermodal the rest is general freight and coal.
Either way you want to slice or dice it 22,294 box cars in a weeks time is a lot of boxcars and 7,464 intermodal cars in a week isn’t all that many…
Those are numbers are from the WEEKLY Weekly Performance Reports from the big 6…I have seen NS intermodal trains that was solid empty intermodal cars-or platforms are they are some times called.I seen CSX intermodal trains that was solid empty platforms.
Here in Michigan we still see alot of boxcars for the auto industry.
The shortline that goes by my school has there daily train with mostly boxcars, and UP(which also goes by my school) in a two hour period on Sundays there would be 2 intermodal trains, 1 auto trains have autoracks and boxcars and sometimes flats with car frames. And we have at least one coal train.
In a large way box cars are becoming obsolete. I work for a company that dismantles railcars and we have seen a large increase in the number of boxcars being scrapped over the last few years. They are mostly 70 ton cars, but also quite a few 100 ton. All types of boxcars are being scrapped including insulated, hy-cube, auto parts, double door and plug door. Most are older cars, but we have cut boxcars as new as 1984. Some are in very poor condition, but a lot have just had shop work performed recently and are in very good condition. Although I don’t expect boxcars to disappear any time soon, they are definitely become a smaller part of the overall car fleet. This will continue as fewer new boxcars are being built every year.
Another reason they are becoming obsolete is the huge up-front costs for a company to do business with the railroad. The manufacturing company I worked for looked into putting in a spur a couple years ago. The cost just to put in the switch off of Conrail’s main was close to 200 grand. Just the switch, and the main isn’t even CTC or anything. Add onto that costs for the remainder of the track and unloading facilities and the price was over a million.
Unless the volume of cargo is through the roof, it is much more cost effective to put the cargo on a truck and send it to the local intermodal yard.
