Is this Decoader fryed
Zepher with TCS 1 decoader. Was running swicher on new drywall covering to check rail groves, it ran about four inch then stoped, hand moved it to no avail.
Have lights
set on program track checked factory reset cv’s 30 was 0, however cv8 is nr.
checked starting volts cv2 is also nr
tried to reset to factory reset with cv 30 and 8, did not work but have lights only. This is the first time I cant get on to operate, thinking I may have fried the decoader??
Thank you for your reply in advance…John
Check the motor leads.
Decoders require resistance between the motor leads for feedback, etc.
David B
I get the NRs from perfectly good decoders. Other decoders of the same brand read back. Go figure.
