Is track with plastic roadbed good or code track better
Hi
I need to know which track would be better on our 2 table layouts. We tried using atlas code100 track but we had to always nail the track down to the table. Then we tried roadbed track and the seemed to look better. I heard a lot of people in Model Rairoader magazine say they use code100 or 83 track but I am not sure what my best selection would be. What would you guys suggest.
Sincerely
Ryan LaPlaca
Is your table set up on tables exclusively for the railroad, or is it on something of a temporary setup?
I strongly recommend the atlas sectional and flextrack. You should glue down a cork roadbed or similar material below the track. You will probably find that the other tracks restrict you more, don’t look as nice when the atlas track is finished and ballasted, and will become more expensive.
“Code” refers to the height of the rail thousandeths of an inch. Code 100 rail is .1" high. code 83 is .083" high. Rail is available in sizes ranging from Code 40 to Code 125. (And larger may be available.)
In HO, Code 100 rail is about the same size as prototype 152 lbs./yard rail, very heavy duty and very rare. If memory serves me, only certain high traffic lines on the Pennsylvania Railroad used this, and after World War II, steel mills stopped producing it.
In HO, Code 83 rail is close to the same size as 132 lbs./yard rail, which is typical of most mainlines in the US.
For sake of appearance, some HO modelers will use Code 83 for mainlines and smaller sizes for sidings and branchlines. I have heard of modelers using heavier rail where its strenght and wear characterisitcs might be helpful, or in hidden areas where the rail’s size won’t detract from appearance. I have also heard of some using lighter rail for complex turnout arrangements where clearances are tight. But appearance is usually the major factor.
Historically, Atlas made its HO sectional and flex track with code 100 rail, but in response to competition and market demand, they began making code 83 sectional track. (In N scale, Atlas made used code 83, but recently introduced code 55.)
Kato And Bachmann introduced track with a molded roadbed.
Personally, I like the Kato track for a temporary layout. If I were building a permanent layout, I would prefer to use code 55 flextrack and cork roadbed, with the track tacked into place and secured with crushed stone ballast, glued down with diluted white glue. (Please note I am in N scale; if I were in HO, I would use code 83.)
One word of caution: if you have non-US made, plastic, locomotives made before 1980 or so, the flanges on the wheels may be too deep for any track smaller than code 100. Replacing or modifying this equipment can be a bit of an undertaking. So if you intend to run some of this older
If it a temp. layout sectional track is the best, but on a more permenent layout I would use cork roadbed with code 100 rail.
