It is not fare to include automobiles as a percentage of Intercity travel for Amtrak and Greyhound.
Private Transportation as opposed to Public For Hire transportation is a entirly different matter. Those opposed to Public Subsidy of Amtrak and other Public Transit should leave the private automobile out. Now you might want to incude rent a car or maybe not. Amtrak carrys 21,000,000 million people G
AMTRAK/AIRLINE RIDERSHIP - MAY 1997
AIRLINE…AMTRAK…Amtrak’s percentage of the airline
Air Wisconsin - 151,228…1,730,000…1,144 percent
ValuJet - 247,787…1,730,000…698 percent
Atlantic Southeast - 336,913…1,730,000…513 percent
Frontier Airlines - 549,000…1,730,000…315 percent
Alaska Air - 1,010,400…1,730,000…171 percent
America West - 1,532,650…1,730,000…113 percent
Southwest Airlines - 4,361,121…1,730,000…40 percent
American Airlines - 6,862,301…1,730,000…25 percent
United Airlines - 6,998,000…1,730,000…25 percent
Delta Airlines - 8,826,824…1,730,000…20 percent
I’m confused. Are the airlines charging too much or did they play rough on the playground?
May I respectfully disagree? One of the prime purposes of subsidizing public transportation today is to avoid the need of expensive and sometimes distructive highway expansion in order to correct congestion and sometimes terrific traffic jams at choke points. In some cases busses can to the job, in other cases rail can do the job better, and in other cases only rail can do the job.
When looking at the subsidies appropriate for rail and bus for a given corridor, all modes should be considered, even air and water if used!
The chart shows that you can do anything with statistics if you want. Air Wisconsin and Atlantic Southeast are both regional carriers and only the last four could reasonably be considered national carriers. Consider the last four as a unit and compare that figure against Amtrak. Keep in mind that a lot of other sizable air carriers would not be included in that figure.
Good points, plus I can’t recall the last ime I took Amtrak to Hawaii, Puerto Rico or Key West.
I agree plus I can’t remember the last time I took Amtrak to Alaska, or to London[:)]
