Its a glue ?
Has any one ever heard of Savo or Sabo Glue I understand you can use it to make “glass” I had a bottle of stuff a while back from Micro Scale I think Looked like Elmers glue but you could spread it around a small area caboose or scale vehicle window frame and it drys clear? Cox 47
yeah, it’s glue. It’s not to hard to make “glass” with it, but it is difficult to make larger pieces with it.
Larger pieces are better left to clear sheet plastic.
Should work for what you want.
Just run a bead around the area you want the window, like the inside of the window frame, then draw the glue across the opening and attatch to the opposite bead.
