Jeff Wilson's Mortar Wash Recipe
Finally getting around to “real” efforts at weathering this week and I used Jeff Wilson’s formula (10% paint + 90% alcohol thinner). My mix is water-based Polly Scale Concrete and 91% iso alcohol. I used it on a test piece of brick-molded wall scrap (styrene), but found it dried very quickly and was harder to remove with a white vinyl (drafting) eraser. In fact, the test piece looks like the 3 Stooges were the masons on that job!
Should I use 70% alcohol instead? Should I wipe the wash before it dries,instead of erasing the overage on the brick face?
Cedarwoodron
I thought you were supposed to use Water with Waterbased paint & Iso Alcohol with Solvent based paint. That might be your problem.
mj
Actually, Wilson’s book mentions water, but states that the alcohol thinner is preferred, as water tends to bead up on the model surface. As 70% alcohol has a greater water component, my question as to using that instead of 91% alcohol remains. I tried the water-and-paint recipe alternative, but appearance of the “mortar” is much less apparent.
Cedarwoodron
I gave up with home recipes for brick mortar and tried this…
http://www.robertsbrickmortar.com/
It’s the easiest and fastest I’ve yet tried. The website states that you can’t mess it up. Put it on, let it dry, wipe it off. And I’ll be darned, it actually works that way.
Jarrell
that roberts brick and morter stuff looks really interesting…
do you have any pictures of anything you’ve done with it?
Yes, here’s an example
and a little closer…
Jarrell
