Jerky BLI M1a DCC
I have this engine apart three times now with out a hitch replacing center gears, I drag heavy freight and it has seen 200 hours plus of rail time. This time around I had to replaces the engine wiring harness.
That is the old harness I replaced, note the bad solder joint on the left side.
This time around things did not go smoothly, in fact it is jerky? I finished reassembly at K-10 Model trains, I lost a screw that held down one side of the motor. We where using a Super Chief DCC with speed steep of 128, engine did not start moving till step 38. Sound was fine but the engine moved, stalled, moved, stalled and moved. At a higher setting jerks where gone (not counting me) sound was fine till I blew the whistle. It was much quieter than normal, it was a quick blast. Then I held the button down and got a hoot, HOOT, hoot, HOOT, hoot, HOOT. Normally that is a sign of a over load, am I right?
Whistle did the same thing with the engine not moving as well?
Couple weeks ago before I installed the body I spun the flywheel and wheels did spin with out binding. Sunday I will pull the body again and double check. When routing the head light wires I did pinch them under the boiler (side question, how do you get the plug thought that small a-s hole anyway? First harness I cut the wires and solder) I don’t see any bare wire, then I notched the plate that connects the cylinders so the wires are not being pinched.
Beside the headlight wires only thing I am unsure of is the red wire from the board. It screws to the chassis under the motor. There is a red pieces of cardboard (for lack of a better terms) that I assume isolates the motor from the red wire that is screwed to the chassis. Installed the red wire with the screw, then red cardoard th
Cuda
Could the cardboard be a shim to space the worm gear and top idler gear? Could be the bind you are getting is not enough space (lash) between both gears.Loosen the motor screws and see if it runs smoother.
Pete
Pete, as a shime I would think rather it be installed first or second after the red wire screw it would make up the same spaces. What do you think Pete?
Thanks for the answer as well.
