Two days ago observed testing on a slightly rising upgrade to the north section of double track between the Eshkol-University intersection on the north and the Shimeon HaTzadik intersection on the south, crossing one grade crossing and a trailing point crossover.
The cars are Alstom modular units. The variety used has five body sections and three trucks, possibly all powered; or, if only front and rear are powered, then higher than usual horsepower. (The starter line is mostly level, but future lines will have steep grades.) The car seems to accelerate as fast as a PCC. It is not quite as quiet as a good PCC, but close, and certainly quieter than any of the Boeing cars that use to run in Boston. It has MU capability, and I did see two-car operation. Since there is the typical ultra-modern streamlined ends without train doors, I suppose this means an operator in each car. The colors are brushed dull stainless steel and black trim.
Couplers pivot to be stored sidewase. There may be cover plates to cover the openings, but I did not see any.
Section 1: Operators cab and sixteen cross seats arranged 2 by 2 front then back then front then back, the first front being good railfan seats to see over the shoulders of the operator. Truck under this section.
Section 2. Two doors each side with four seats facing the aisle on each side between the doors.
Section 3. Center section, with the double-end car symmetrical, sixteen cross seats arranged like the end sections. 4 repats 2, and 5 repeats 1.
Comfortable seats, blue upholstery.
There is also an operators door in sections 1 and 5, on the left side for quick crew swaps.
About 1.7 miles of the 24-mile line (appr
