JL Gas Pumps
I have a couple of HO scale gas pumps from JL Innovative design. They come as three pieces. The pump, nozzle and a piece of wire for the hose. I got the 40’s/50’s version. Anyone have any tips on assembling them? Pictures?
Thank you in advance,
Mark
Do you mean these pumps?
Or these pumps?
Either way, they’re pretty straightforward. Because of the dissimilar materials, I used CA (Cyanoacrylate, or Super Glue) to attach them. Put a bit of glue on the tip of a toothpick, and use that to apply it. I think I put the nozzle on to the hose first, and then bent the hose to shape and attached that assembly to the pump body. For the second picture, I left the hose extended (the wire is stiff enough to hold the shape) so the nozzle could be filling the car.
