I decided to try Joe Fugate’s scenery plaster mixture and this is what I came up with.
I live in Sweden and the hard part for me was to find the right material. After many questions and a lot of thinking I found similar products here in Sweden. Not that easy but I did it. And I want to share it with you all, if it happens to be a Swede listening [:D]
Where did I get the material?
Vermiculite 1-2 mm, use 1 mm if you can find it. What a nightmare!
It cost around 1-2 USD for 1 litre (10 SEK/liter) and looks like this.
Patching plaster. I found it at a wellknown store called COOP.
It cost around 11-12 USD for 5 kg (89 SEK för 5 kg, kallas gipsbruk, danogips) and looks like this.
Cement, also found at COOP. It cost around 5-6 USD for 25 kg (45 SEK för 25 kg) and looks like this.
How do you mix it?
First of all, protect your eyes, you don’t want plaster or cement powder in your eyes!
Use 4 parts of vermiculite, 3 parts of patching plaster and 1 part cement.
I don’t know what this is called in english (scoop?), but I used it, and it worked.
Put the vermiculite, patching plaster and cement in a plastic box and shake well for a minute or two.
Mix it with 3-4 parts of water. You must try this out yourself. All I can say is that you wa
