Joining Tubular Track
Are there any tricks to getting new tubular track to join together tightly? It seems that no matter how much force that I use, I can never get the rails to but together tightly. There is always a gap of an 1/8" of an inch or so because of the rail pin.
Any ideas?
Thanks.
In the back of CTT there is a device for sale for joining track. It’s a little vice that pulls the track together. I don’t have a copy here at work, but I’m sure someone can give you the info.
When I was building my layout I looked into that clamping device, unless you were into a major layout, or a pro builder, it seemed pretty pricey. I used a block of wood and light hammer to drive the tracks together. With some pins there is a slight ridge/ring at the center and if you force the rail over this there is a slight bulge at the joint.
What I usually do is join them together with a rocking motion that tends to sort of spread out the opening and make them go together easier. I have also heard of people going one rail at a time, although I never have tried it.
What brand are you using? I have never had this problem with Lionel, Marx, nor K-Line.
I recently purchased a bunch of Lionel O27 track and experienced the same thing. The fit between the pins and the rails is extremely tight, which is a good thing. My buddy at the hobby shop told me lightly lubricating the pins helps the problem.
Jim
Thanks for all of the replies. I have been using Lionel O-Gauge track. What type of lubricant did you use for your track?
Watch out on using lubricant, it may affect the electrical continuity through the joint.
As long as the lubricant does not have any solid non-conducting particles in it (e.g. teflon) it should be fine.
Daniel Lang
I do what Roger does: Use a small block of wood and a light hammer to gently tap the rail ends together. Works fine for both O27 and O gauge tubular track (any make).
I don’t use the trackpins. I solder the sections together.
Here’s a scan of the track vise ad that was referred to above, from the CTT mag:
http://ca.geocities.com/ambassador_martok/1dayfiles/Ttracker2.jpg
