July TRAINS item on electrification - the "FL9" solution?
On page 10 of the July issue of TRAINS there’s a brief news item regarding the possibility of reviving plans for electrification due to the high cost of diesel fuel. The consensus conclusion of the author seems to be that mainline electrification is still too expensive even with today’s fuel prices due to the upfront costs of stringing catenary and buying whole fleets of electric locomotives.
Taking a cue from the “Milwaukee Road Innovations” thread, I would like to return to the idea put forth a while back regarding the concept of converting some of the current fleet of diesel-electrics into dual power locomotives in the vein of the old FL9 concept. We all know that diesel electrics draw their current from on board generators turned by compression-ignition engines. How hard would it be to add-on the necessary components to today’s modern diesels that would allow the traction motors to draw current straight from overhead wires?
The point is, this dual power mode method would allow for electrification sections to be limited to the most energy intensive portions of a line, aka mountain grades. That would certainly be a lot cheaper than electrifying whole subdivisions and buying whole redundant fleets of eletric-only locomotives, not to mention eliminating locomotive changeovers between electrified and non-electrified portions of the mainlines.
Any takers?
From the standpoint of the electrical system, an AC locomotive would be the easiest to convert as it already has a (more or less) constant voltage internal power bus. This is pretty much how the hybrid GE locomotive works - the battery is effectively placed in parallel with the rectified output of the traction alternator - for a modern ‘FL-9’ replace the battery with the appropriate current collection device (pantograph or 3rd rail shoe) and voltage conversion circuitry (if needed).
Making this all fit mechanically would be a different story. It would probably work best with a relatively small prime mover to allow room for the electrical gear (and pantographs).
Converting a DC locomotive would be more of a challenge as the Lemp system does a pretty good job of providing a constant power output from the generator/alternator over a wide range of loads (though things got to be pretty hairy with the GP35). Modern power electronics can provide similar functionality, but it is no longer a case of simply putting the external power in parallel with the output of the traction alternator.
I would not have thought it would be too difficult to make a diesel loco into a hybrid. It’s been done in Britain, so if we can do it within the constraints of the British loading gauge, it ought to be a peice of cake in America. At the present time Virgin are rumoured to be considering converting their diesel electric Voyager trains into hybrid Electro-diesels by adding a pantograph and a rectified to the centre car; this would then feed in to the power bus cable that runs along the train. At present these trains spend a lot of their time running on a electrified lines; this conversion would enable them to draw power from the overhead and thus save diesel fuel.
Montreal and NJT have a request for proposal out on just such a beast. I were a frt RR, I’d certainly have my eye open watching this develop. I’d also be pushing the legislative end to get fuel tax money made available for strining catenary, selling the environmental benefit and offering up improved passenger service as a public benefit.
The “FL9” was as Diesel locomotive with DC traction motors that EMD rigged to pick up voltage from the 660 DC outside Third Rail in the New York area, as well as its own diesel driven generator. Full of bugs when first put into operation, the system has lasted 50 years. It’s still is a good way to go.
To pick up power from 25,000 AC volt overhead wire you start with a LARGE transformer. (this takes up a large part of an electric locomotive carbody) and when down to the 600 volt range rectified to DC. (even if AC “VVVF” control is used) This would be one BIG and HEAVY locomotive. (diesel and transformer)
Todays remaining overhead wire systems were installed by the New Haven before World War I, by the U.S. Government on the Pennsylvania in the 1930s as a “make work project”, and the last leg to Boston by Amtrak (a U.S. Government agent). To add more wire or third rail, could a Local or State government justify to the voters such a large cost? I think not. The FL9 approach is the one that would be “cost effective”.
The private for profit railroads seem happy to buy new, state of the art, locomotives from GE or EMD. Run them for 20 years and then sell them to Regional Railroads for another 15 years of service.
At the risk of being tarred and feathered, I am going to suggest that the FL9 was overrated and undermaintained. It was proposed as a way of replacing both aging diesels (DL-109’s) and aging electrics in one fell swoop. NH was quite short of operating electrics at the time the FL9’s were ordered and the original plan was to operate them in the electric zone in peak periods only to take some of the load off the power plant. Remember, they were not equipped to run off of the AC catenary. The dual-power provision was only to allow them to run into GCT, and as the years progressed and proper maintenance lagged, some of them were running into GCT on diesel power.
The FL9 was offered to both PRR and NYC, but neither road purchased them. Both roads continued to change power at the end of the electric zones.
Currently, both Amtrak and Metro North operate dual-power locomotives but it would be useful to know how much time they actually operate off the third rail. I would suspect that they cut over to conventional diesel-electric operation as soon as they reach open air, even within the electric zone. Additionally, Amtrak’s dual-powers don’t operate west of Albany on the Lake Shore Limited, so a change of power is still involved.
Electrics aren’t small or cheap for a reason. There is a lot of heavy duty electrical equipment under those hoods to convert AC to DC. the reason for AC is it’s much easier to send long distances and much more practical to do so. DC electrification went out around 1900 and hasn’t come back so nothing has been developed to do so. With a DC system on a third rail already in place it was “fairly” easy to make them dual power but nobody is going to install a new DC system on tracks where there is possibility of trespassers turning themselves into carbon due to the liability and the operating costs. It would also be virtually impossible to fit a diesel and an AC electric system in a carbody. Don’t forget a major factor in the cost of electricity is it takes the most BTUs to produce work. You still have to burn something to make heat to make steam to turn generators and then distribute that over wires to where the work is to be done. Every step has energy losses. Plus you have all the energy costs of smelting all that copper and steel in the first place and then hanging it. The answer may still be the steam engine using high sulfur coal with scrubbers on board. With modern materials and polution devices it may just be the most practical solution some day.
It’s not so much weight as complexity and space, for high-power AC hybrid. The standard Siemens Eurosprinter is a 4-axle 8500hp AC electric with 3-phase drive with a weight of 84-85 metric tonnes (about 93 US tons). With a DC overhead you run into the need for heavier cabling and heavier support structure, more substations, etc. The equivilent of two SD70s would require 4000 Amps at 1500V DC which is about the limit for Amperage. With 3000 V. DC you could operate 4 SD70s. But its not uncommon to find that many on one train, so only one train could be in each cantenary section drawing full power. On busy mainlines, which is where you would electrify, that would be difficult. 6000V DC has been done, but it gets too complicated inside the locomotive for any kind of hybrid. Prices for a straight electric should be competitive with current Diesel-Electrics when produced in similar volumes.
Regarding existing US hybrids, both the EMD FL9 and GE P32ACDM have significant limitations on 3rd rail power. Amtrak has instructions to train crews to switch from 3rd rail power to diesel as soon as they are out of the tunnel, unless the diesel won’t start, in which case they must notify the Dispatcher immediately, and then permission to run on electric will be given to run on 3rd rail to Croton-Harmon, where help can be obtained.
It is probably safe to say that 99% of DC electrification has been installed since 1900; 1900-1956. A 1999 European railway electrification conference showed several papers presented on improvements in DC railway electrification. Research is continuing in this type of system; indeed, at that conference there were nearly as many papers on various aspects and developments in DC design as AC related papers.
The idea of a dual-source locomotive makes little sense. EMD pitched a specific design to the Milwaukee Road in 1972, converting SD40 locomotives to alternative 3kV DC by the addition of a pantograph and related control equipment. Naturally, it cost more than either the straight Diesel or the straight Electric. This meant, when being used in the Diesel mode, it cost more per horsepower than a comparable Diesel-electric. When used in the electric mode, it cost more per horsepower than a comparable straight Electric. On 600-800 miles runs, there just wasn’t a cost savings compared to simply switching motive power.
Too, combining a subsystem with a 92% availbility (the Electric) with a subsystem with 84% availability (the Diesel-electric), the resulting availability of the dual-mode machine was 76%, requiring more such machines to haul the targeted tonnage.
Too, the concept undercut a key advantage of a straight electric locomotive – the one-third cost of maintenance and the 30-40 year economic service life. Each dual mode locomotive gave up all of the mechanical and service life advantages of the straight electric – key reasons for electrifying in the first place.
Finally, every time one was used in its diesel-electric mode, crucial electric horsepower was unavailable under the wire – and that was what the fleet investment was for in the first place, and also the limiting factor. It was a poor use of e
One point not mentioned in the article that needs to be brought up, is the effects of Tier III and Tier IV Emissions Standards when they come into force. They will likely have an impact on the economics of electrification vs. Diesel-Electric, by raising the cost of new Diesel-Electric Locomotives and probably their on-going maintenance costs. It looks like Diesel-Electrics will need to have Catalytic Convertors and probably Particle Filters which will require periodic maintenance, and replacement. Tier III is guaranteed to happen soon, and Tier IV is in the early stages of discussions concerning what is possible. Another point is that California may force the issue of railroad electification.
Suppose it were decided that all U.S. railroads would electrify. There would be the cost issue of new catenary and new locomotives, but what about the cost of power? How many new power plants would be needed to power all U.S. railroads? And what would this new demand do to the price of electricity for railroads and for general customers? And what would be the cost comparison of sequestering all CO2 from all railroad diesels, versus sequestering it from the coal fired power plants producing power for electrified railroads?
None.
Probably lower it.
Assuming, arguendo, that “CO2 sequestration” survives the current media hysteria and bizarre Supreme Court decisions, this is one factor that will act in favor of railroad electrification.
Now, now, no one is going to tar and feather anyone on this thread!
Paul,
What is your opinion of the Fairbanks-Morse P-12-42…?
http://en.wikipedia.org/wiki/FM_P-12-42
It seems this FM product was superior to the FL9 in many ways - better fuel economy in diesel mode, higher max speed (117 mph vs 70 mph for the FL9) - but was overlooked (or undersold) vs the EMD product.
For what it’s worth, I feel any locomotive that lasts 50 years should be given respect, despite the misgivings!
It’s not often that I have a disagreement with Michael Sol, and granted I’m in over my head on this subject, but here goes…
In this analysis, you’re continuing to maintain two separate fleets. But what if the dual mode locomotive allowed for a 1 for 2 replacement, aka 1 dual mode locomotive replaces 1 straight electric and 1 diesel?
BTW - what was the proposed cost of the dual mode locomotive, at least relative to the costs of the electrics and diesels? In other words, was the cost of 1 dual mode less than the cost of 1 electric and 1 diesel? Same as? More than?
In the context of Milwaukee’s decision to end electrification due to the expense of catenary rebuild, wouldn’t the dual mode have allowed for some limited sections of catenary to be removed (aka Deer Lodge to Haugen), with the subsequent useful parts redistributed to the remaining sections of catenary?
Where did these numbers come from? Were they drawn from spec analysis, or did EMD actually provide a dual mod
Well, a locomotive can only be in one place at one time.
Maybe an example.
Milwaukee Train # 261 generally arrived in Harlowton at 9:45 p.m. powered by 4 SD40 locomotives, 12,000 h.p. At Harlow, a 6,000 h.p. Little Joe electric was put on. The SD40 had a 1,020 ton rating from Piedmont to Donald, the ruling grade on the run, at 18 mph. The Joe was rated at 1,440 tons at 25 mph. on that grade. The train on April 28, 1972 was limited to 50 cars, 3500 tons. The Joe was taken off at Avery and the train ran on with the Diesel engines to Tacoma arriving at 4 a.m. 31 hours later. At Avery, the Joe could be turned and run eastbound on 262 in the afternoon. Basically, it was that Joe running over the three mountain ranges on the Rocky Mountain Division that gave both 261 and 262 their fast times. Train #262 likewise left Tacoma with a four unit SD40.
So, the “train cycle” for #261 and #262 involved two sets of four SD40s, eight total, and a Little Joe Electric that swung between the two trains for the Rocky Mountain Division run. The cost of the train cycle was
The availability of the straight electric was determined by GE from actual experience on the Milwaukee with the GE 750 class, with 25 years of operation – an extraordinarily good availability for an old locomotive. EMD supplied the availability figures to GE from general fleet experience of the SD40/SD40-2. The resulting availability is a statistical measure. The cumulative probability of independent events occuring is additive of the probability of each independent event occuring.
I believe the combined availability number would be correct for both subsystems (Diesel-electric and electric) to be simultaneously operable (system availability). This would be the number to use if the combined unit had to use both the Diesel-electric subsystem and the electric subsystem at the same time. If the combined unit used only the electric subsystem under catenary and only the Diesel subsystem while not under catenary, then one has to take into account the fraction of the trip under catenary to get a detailed estimate. Depending on what that fraction was, the availability of the combined unit for the trip would be somewhere between 84% and 92%.
If Diesel operation was permitted under catenary, although not preferred, then the Diesel subsystem would have been a backup to the electric subsystem. In that case the likelihood of the engine being inoperable while under catenary was .08 x .16 = .0288. So the availability of the combined unit under catenary was 97%. The electric subsystem is not relevant when not under catenary, so the availability when not under catenary was just the availability of the Diesel subsystem, or 84%. In this case the availability for the trip would have been somewhere between 84% and 97%.
[quote user=“MichaelSol”]
Maybe an example.
So, the “train cycle” for #261 and #262 involved two sets of four SD40s, eight total, and a Little Joe Electric that swung between the two trains for the Rocky Mountain Division run. The cost of the train cycle was as follows:
Little Joe equivalent: $540,000
SD40s @$270,000 = $2,160,000. Total cost for the equipment cycle = $2,700,000.
The dual-mode SD40s were estimated at 140% of the cost of the Diesel-electric version of the SD40, although another estimate was 180%. Using the 140% estimate, the bad news: in diesel mode they put out 3,000 h.p… The good news, in electric mode they generated 5,400 hp… So, #261 would still need four of them to haul the train in Diesel-electric mode, eight for the total cycle. Cost $3,780,000. But, with four of them, at 5,400 hp in the electric mode, the train has 21,600 hp. compared to the 18,000 hp in the combined system. The extra horsepower doesn’t really do that much good, but it costs $1 million more to have it there, because you still need the four locomotives to power the train where there is no trolley, but it only cost $540,000 to have it there where it was needed in the form of a Littl
While I’m rarely in agreement with Michael Sol, I’d like to thank him for quantifying quite thoroughly what many of us have been trying to say, that dual-mode isn’t all that it’s cracked up to be. In the case of the FL9 and the P32’s, dual-mode could be considered an expensive addition to cover a specialized situation. Note that a prior post indicates that Amtrak’s operating rules state that the P32’s operate in diesel mode when they’re outside the tunnels and station. I would think that Metro North has similar rules. Others have pointed out the mechanical complexity (higher maintenance costs) involved in a dual-mode design.
Dual-mode is like a lot of other ideas: it looks good on paper but falls flat in the real world.
The FL9 was a “one of a kind” group of locomotives built to The New Haven Railrod spec.
It’s the 1950s
  1. Hourly train service Boston to New York required a switch of locomotives from Diesel to Electric at New Haven. A loss of 20 minutes on a 4 hour schudule. The DL109s have long gone to Commuter Service. The main line is ruled by PA1s amd FMs, always operating in pairs.
  2. The Power Station for the New Haven’s over head wires (11,000 volt 25 cycle AC) was at Cos Cob, CT. It was built in 1903. It was long over due for replacement. Added power was being bought from Conn Edison (NY) and United Illuminating (Bridgeport).
  3. All Electric Locomotives dated to the 1930s or before. EXCEPT, the brand new, 4000 HP EP5 Rectifier Electrics from GE designed to move passenger trains from New Haven to New York at 80 mph.
  4. The president of the New Haven has left, the new President is the company “bean counter”. Is there any option to save replacing Cos Cob? Enter EMD. They have never bought from EMD!
  5. EMD can make an F9 that could run from the New York Central 660 DC third rail into Grand Central Station (Terminal).
  6. Big Problem, The axel loading is much too high for the 125th Street Viaduct that leads to the Park Ave. Tunnel. EMD will make a new model, a 5 axel diesel!! Four wheel front truck, six wheel rear truck and add HEP. We have the FL9 (L for long). Running in pairs, back to back, 4000 HP at 80 mph. The same as an EP5 electric.
  7. After de-bugging, they ran well, and, with multiple rebuilds lasted 50 years in Main Line Service. Know of any other diesel has done that? Today, the are still available as reserve power when needed, meanwhile being used by local tourist lines.
  8. Oh yes, another big problem, The New Haven had “long trem” contracts with the two local power companies.
