Yeah I do not have power pickups on the tender. Just the leading trucks, driving wheels, and trailing trucks. I took apart the loco and verified it with my own eyes.
So what I’m going to do is to cut off the four pin connector and the two pin connector, and solder wires going to the back of the loco that connect the trailing truck wire pickups to the tender pickups.
In the picture below, you can see the tab at the rear of the split metal frame that the trailing trucks have wires connected to them.
At at the time the K4 model was first produced in the late eighties, 1361 had recently been restored to service after being on display at Horseshoe Curve for many years, and was in active railfan use. 1361 as modelled shows a late version of the K4 with the solid pilot. Spectrum has also offered an early version with an open pilot, which I assume is what the “K4 Classic” is??
