do i put it in there like his:
http and so on with this at the end
or
one of the two has to be correct i need to find out how to post so please help
or
Reggie,
If you go to the “Sunday Photo” listing, Tom has the instructions to how to post photos. If you have problems with that (I did), the guys will tell you what you did wrong and help.
Dennis
I have only posted a couple of photos but remember having issues that seemed to come from using Netscape. Once I got into to IE things were fine…
just a thought…
Jim
Use the same text you used on the first example, but use the brackets rather than the < > brackets.
As an alternative, rather than using the quick reply, click “reply to topic” at the bottom of the page above the quick reply box. There’s a button on the page that comes up that will insert the correct image tags into your reply text. It’s the one that shows a little image of a mountain and the sun. Just copy your image URL between the tags.
