Just got my 0-6-0 Lionel Dockside Switcher - got a problem...
Haven’ t run it yet due to the fact that there’s a wire prominently visible in the cab. Should I take this back to the store? Or try to fix it myself? It appears to be pretty tight, so I don’t know if I want to mess with it. If I get a chance, I’ll take a picture and post it.
I have one of the same switchers, I will look at mine and see if it has the same wire there.
Bump for dougdagrump.
Took it to the store yesterday - apparently the wire is for the reverse light (I thought it was a loop of wire stuck up into the cab from the control board - my bad) on the back of the cab, and that’s the best they could do as far as running it.
From ant29: the problem is the workmanship is not what was. Have the service Dept
solder the wires first, before putting on the wire connectors.
aloha ,Tony from hawaii,ant29@prodigy.net a lionel repair tech for honolulu trains&
hobbies for 30 years.
Huh?
