I just updated two beeps to TMCC with a kit ($65 each) from www.electricrr.com. I did not add sound (I have a sound car for that). It was a no solder installation which is good because I am not fond of electrical work, especially soldering around expensive boards. I was nervous cutting wires off the existing reverse board, no turning back now! The instructions were very clear and the units are now working! The nice thing about beeps is I can always switch shells, I do not have to fork out the money to convert all my Beeps to command.
The beeps seem to stall less on switches as now I run the track at 18V and the lights are much brighter. I highly recomend this installation even if you are timid about electrical modifications (like me!). I think he also sells beeps with TMCC already installed for $100. If I had it to do over that is the route I would take.
Jim H
Jim, thanks for the info. The video on the website really sells the product. Do you know if the BEEP TMCC kit works for the Lionel Docksider?
I am not sure about docksider, but if you send him an email he is very good about answering.
Jim H
Good. I’ve upgraded GP9’s and old U36B’s with kits from Digital Dynamics. Buckeye, probably will work as I think the limiting factor is AMP draw from the motors. The small motors work well with them. DD has the mini boards too.
Buckeye, I read some posts a while ago regarding the docksider and putting a board in it to upgrade. First, they had problems getting into the engine, second, they did not have enough room to put it in. I have not personally opened up my dockside, so I can only go on hearsay.
dennis
The Docksiders can be upgraded but I can’t remember which boards are used. However, I believe the only thing that could not be included was the sound, insufficient room. [%-)]
Dr. John,
I had to go with an older version (Edition 5, published 1995 or 1996). I figure the prices might be a little off but I can update the ones I am interested in by watching ebay. Plus it should be good to keep me from way overpaying.
Jim H
