Just What Is A Railroad Watch?
Kent Singer
November 2000
Collecting Railroad Watches
A large number of pocket watch collectors focus on railroad watches. These were amongst the highest grade watches made, perhaps being superseded in time keeping quality only by presentation watches and navigational chronometers. Their high value and prestige, coupled with, in many instances, lower production quantities and, of course, the vast romance of railroading, are what make these watches attractive to collectors.
There are a number of watches which are so widely recognized, and known to have been accepted for railroad time service, that their grade names practically scream “Railroad Watch!” Examples of such are:
However, sooner or later, just about every collector, from the novice to the expert, comes up against an unusual watch about which the question arises, “Is this a railroad watch?” In attempting to form an answer, the more basic question then becomes evident, “Just what is a railroad watch?”
Chaos
The easy answer to that question is that railroad watches, referred to in the railroad industry as “standard watches” (because they met the railroad’s standard), are those watches that were accepted for railroad time service. The problems in using this definition become evident when the following facts are contemplated. First, different railroads accepted different watches. Then, while some railroads listed specific makes and grades as acceptable, others just listed requirements.
(Click on the illustrations for enlargements)
Fig. 6: In 1906 the Ball Time Service specifically approved this list of watches to enter service on a division of the Pennsylvania Rail Road. The full set of requirements are on pp. 84 & 88 of the January 17, 1906 issue of The Jewelers’ Circular - Weekly and Horological
Well, I gotta admit - I was curious regarding the thread title, but no offence … you actually think I’m gonna read all that !?! [:O] I started to … but … well … [zzz]
What exactly is your point ??? [%-)]
Mark.
[#ditto]
Tracklayer
After some boiling down and distillation:
Railroad Watch*.* A timepiece to be carried by a working conductor or locomotive engineer and used for assuring compliance with the Employee Timetable and Train Orders with time-specific instructions. It had to be:
  • Built to the accepted Company and/or AAR specifications at time of manufacture.
  • Fully documented; manufacture, required checkups and repairs made.
  • Checked against Company standards at the specified intervals - or less - and found in compliance for continued use. If found non-compliant, it was repaired or retired IMMEDIATELY!
All the rest is fluff, froth and distillate (undrinkable, unfortunately.)
Chuck (modeling Central Japan in September, 1964 - where time was King, and the d’raiba hung his certified watch right next to his schedule card)
Timepieces have been important since the sundial. Stonehenge may be a huge heaving version keeping track of seasons as well. It comes down to when do you plant, when do you harvest, etc.
I worked on making fast clocks for the club layout, experimenting digital readouts, what worked was a computer version on a TV screen.
Probably the railroad was responsible for a watch industry to make precision watches for railroad use. The ole common image of the engineer comparing watches with the conductor and setting them together was a common scene.
The meaning of a Railroad watch meant its high precision accuracy and reliability. Prolly helps to make the difference than some cheapo second hand watch maker.
