K-Line switches
I am looking for two (2) K-Line 0-27 switches, Model no. K-0275. K-Line does not have them in stock and told me that they were back-ordered and to expect shipment in spring of 2005. Well here it is already almost fall and still no switches. I have been sending e-mails to different dealers/hobby shops in the hope that I can find them. I need to replace two Loionel switches that don’t work. My Hudson locomotive stops in them and the switch then just buzzes as if it is trying to change positions. I have them hooked up for constant power, not track power. The other K-Line switches I have on my layout don’t give me any trouble at all.
I would check eBay for the switches. There is a K-Line Model No. K-276 auction there now. You may get lucky and eventually find the K-275’s.
Robert
http://home.surewest.net/rlplionel/Robert.htm
Are you using 027 track? Another switch to try may be GarGraves, you will need mating pins but the track will match the rail size of 027 just right.
Lee.
I bought 12 of the 27" variety at Imperial Trains near Pittsburgh. You might want to try them.
  • walt
