Hey guys. I just partially finished my layout , but all the track is hooked up.
I wanted to test it so I hooked up my CW80 transformer to the track with the K-Line universal lock on. There is no power. My passenger car won’t light up, the train won’t run. The lock on does’nt work. What should I do?
Thanx,
Colin
Check the reset button on your transformer. Then make sure you don’t have a short anywhere, like wheels off the track. and try again.
Happy 2000 Spanky!
Snell, Could there be a broken wire of some sort? Did You look?
Have you checked to make sure it’s snapped all the way on?
I have several dozen lockons, among them several K-lines, and I have found that the K-lines are especially bad about popping off the track. If you’ve got the one that I’m thinking of, it’s designed to be used on both O and S gauge track, and, as such, doesn’t fit on either one quite like the correct lockon does. I still use them because I have both, and find having some lockons that will work on both types of track convenient, but, like I said, they don’t have the best fit in the world.
Thanx guys…I finnaly got it to work!
Thanx Again! ! ! ! !
See, You just need to try
