KA4 for Paragon 2 decoder
Hello,
I’m somewhat new to DCC and decoders, with a very basic electrical backround. I purchased a EMD SW1500 with a paragon 2 decoder installed, and I have been having some troubles with low speeds around some turnouts that have powered frogs and have clean rails. I was intereseted in purchasing a KA4 Keep Alive Cap. and would like to install it however I’m not sure where to install it. Not sure how to upload a picture on here, I’m new, but if anyone knows what the paragon 2 decoder looks like it would be helpful to know where to put the wires for the Cap.
Easy Simplistic replies would be appreciated.
Thanks
OK, I’m gonna try to revitalize this topic. I contacted broadway limited and this is what they stated. They did give me a brief description of some of the pins which was for a different model but I could follow along and make an educated guess as to which pin was what.
Broadway: “Our Paragon2 decoders come equipped with a capacitor to keep the engine
going during a very brief interruption in power, is the engine having a
problem while going over a frog or a switch?
The reason I ask is because you may not need to install a Keep Alive if
there is something going on with that engine like a pickup issue - if
that is the case we can definitely assist you.
We do not support upgrades/modifications here in the service bay, and we
do not have any experience with installing a Keep Alive on our decoders.
Because of this, I do not know where or how you would hook up the wires
for something like that.
Please be advised that any malfunction of the decoder due to
installation of a Keep Alive is not covered under warranty.
Pin outs can vary based on what is programmed into the decoder.
JPGM: Serial wire (usually used for chuff on a steam engine and/or
programming)
J1: Pin1 = Front Light
