[?] Has anyone changed the horn hook couplers on a Riv. centipede tender to Kadee? Would really appreciate knowing how to do this.
Thanks, Hank
WELCOME ABOARD!
Assume HO, so for starters, http://www.kadee.com/conv/hocc29.htm
HO is correct. Should have remembered Kadee’s web page. Good diagrams and explanations. Now all I have to do is complete the job.
Thanks
hanklalonde,
You ill probably find it much easier to use one of the special McHenry couplers that plugs into the Rivarossi link just like Rivarossi couplers do. It’s the only application of McHenry couplers I use but it is unbeatable. Making a Kadee fit will mess up the model and may not work well anyway.
Mark C.
I once fitted a kaydee and it’s box onto a brass plate that contained airhoses etc and put a very very big screw thru the bottom. Everything kinda fit. Last I heard it’s still on there. In a few weeks I should have a picture of it.
Good Point! www.mchenrycouplers.com Get the the newer version with the coil knuckle spring.
You may have to contact them by e-mail for the right replacement.
Emailed McHenry for advise on which coupler to use. They have some for Rivarossi but don’t specifically mention centipede tenders. If you know the type let me know. If not, I will post when I hear back from them.
If all else fails, and you want the best operating coupler, cut off the existing box and mount a #5 in it’s own box. The only trouble you may encounter is proper coupler height. May have to shim or have to use an overset or underset knuckle.
Bob K.
