Kadee magnetic uncoupler works great
That would be an electromagnet version.
Hello All,
When I began this great hobby in 1972 “Hook & Horn” FX2 couplers were the standard. Yes, Kadees were available but not the norm.
The FX2 were made of plastic- -no metal components.
Hence a magnetic field, no matter how generated, could not uncouple them.
There were uncoupling ramps to allow remote uncoupling.
Some of these ramps were electronically actuated.
The actual uncoupling action was physical, not electronic.
Lionel had many “action” cars that were mechanical in operation but electronic in actuation.
Press a button and an electronic pulse actuated a solenoid that physically created the “action”.
Unlike, the magnetic (electronic) action of an electromagnet.
What “willy6” is describing is the Lionel system of an electronically actuated physical movement.
Not, as you erroneously describe as…
Again, your exuberance of youth has overshadowed knowledge gained through life experiences.
Hope this helps.
I didn’t say it was magnetic.
It would be electromagnetic of course. It would not be electronic any more than your doorbell was electronic.
It’s merely electrical, like a doorbell solenoid or the buzzer you may have made in shop class. Electronic devices use electron flow to produce electrical results. Electrical devices, including electromagnets, use electron flow to exert mechanical force or switch on a light.
Semantics are not easy but best not to try and outdo me in that field.
I installed and tried a Kadee #309 HO scale under-the-ties delayed action electric uncoupler once. Just apply DC current, no moving parts. Did I mention, just once.
Try the #322 instead. It’s newer.
I finally had time to dig it up. This was from before I somehow lost my login abilities under my long standing original forum name “Southgate” (not 2)
Hope the link works:
Mechanically Operated Uncoupling Magnets. - Model Railroader Magazine - Model Railroading, Model Trains, Reviews, Track Plans, and Forums
or try…
cs.trains.com/mrr/f/11/t/269369.aspx
Copy and paste the above, it’ll get you to a search, that will get the post.
Don’t judge it by how cheap it looks, cuz, yes, it does. Devise a more expensive way to lift the magnet if you must. Everyone who sees it in action is amazed.
There are some things I would edit, but I can’t get in! Dan
