I have Kadee coupolers and a plastic kadee uncoupler (yellow) with a point on one end and a spade tip onthe other. How is it supposed to work on the Kadee couplers on my cars? The pointy end does nothing, the spady end doesn’t seem to do anything either. Looking fo a tip or two on how to use this thing,
The pointy end works the same way: insert between couplers and twist. I have several that I made with a 4" length of dowel and half a grocery store bamboo skewer.
I haven’t used the Kadee coupler pick, but I have used the wooden skewer method. There is definitely a learning curve. I have watched “experienced” folks make it look easy. I’m still on the other end of the curve, not too far from the start. The proper slack, mentioned above, is definitely a big part of success.
OK, with a little practise, I am able to see how the spade-y end of the skewer works, ( slacken cars…insert spde btwn couplers…clockwise twist…repeat as necessary) I will also practise with the pointy end; and I do recall seeing pictures of the MR staff with pencils in hand separating cars. Thanks for all the suggestions. The rest is up to me, obviously.
