Kato Concrete vs Wood Ties
I’ve been working into the MR hobby over the past few months…reading, watching videos, setting up and running a basic oval layout, etc. One area I’m still not clear on is Kato Unitrac ties. Some questions I could use some help with: Are all Kato Unitrack pieces available in both concrete and wooden ties? Is the only difference between the two modern vs older? Is Kato phasing out the wooden ties? And in general is there anything else I should know about?
[#welcome] to the Model Railroader magazine discussion forums. Your first few posts will be delayed by the moderators, but that will end pretty soon. Please stick with us through the delays and become a regular contributor.
No, not yet. You did not say if you were in HO or N scale. N scale has a lot more variety, but there are pieces in both HO and N with either wooden or concrete ties modeled on them
Sort of. Most newer class 1 mainline track in North America is built on concrete ties. Turnouts and crossings still favor wooden ties from what I have seen. Smaller sections of new track are still being installed with wooden ties.
I seriously doubt it. There will always be plenty of modelers around that model a time from before there were any concrete railrod track ties.
-Kevin
Eventually you will want more than an oval. Perhaps you are there now.
Read this book first. John Armstrongs’s Trackplanning for Realistic Operation.
Thx Kevin - very helpful. I’m going with HO. Played with an oval of N Scale and found it to be too small for my older eyes and fingers.
I have a ton of HO Kato Unitrack. It allows me to set up trains and run them anytime I want even though I do not have a layout right now. It is very high quality stuff.
I learned decades ago in N scale, that using Kato Unitrack for all hidden trackage makes maintenance many times easier and installation a breeze.
I intend to use the Kato Unitrack for the hidden trackage on my next HO layout.
-Kevin
Currently in HO Kato only makes three lengths of straight track (4-7/8", 9-3/4", and 14-1/2") with concrete ties, plus their 9-3/4" feeder track, and superelvated curves in 28-3/4" and 31-1/8" radii. The superelevated (or ‘banked’) curves are not available in the wooden tie regular line; but the three lengths of straight track, along with other straights, curves, turnouts, etc. are. The pieces are all interchangeable, except you do have to use the easement or transition track for going into and out of the superevated concrete tie curves.
Good stuff. Will stick that info in my layout file. Will keep me from planning something that can’t be built.
