Kato HO SD40-2 disassembly help
having difficulty in removing the body shell. Where are the points to squeeze on the body in relation to either the trucks or handrail stanchions. Thank you.
Great units, I have 4 of 40-2s and 3 of the 45s
Pull the couplers.
Remove the railings where they attach to the cab at six points
Grab the fuel tank with one hand.
Grag the shell behind the cab with your other hand.
Pinch the shell inward and rock the shell side to side.
Repeat if neccesary in the center of the long hood and at the end near the cooling fans.
The shell may come apart at the walkway or the shell and walkway may come off the frame as a unit.
I always assembly the shell to the walkway and press them on the frame together using the same rocking motion.
