Kato N-Scale Kinematic Couplers for their Southern Pacific Morning Daylight
For more than a year now, I’ve had a Kato N-scale Southern Pacific “Morning Daylight” train at long last. I’ve finally started test-running the train on a simple oval of track that I’ve extended using a UniTrack oval as well as the bits of UniTrack that are included in the set. The one major issue that I’ve encountered is that the cars’ couplers tend to uncouple, but with the replacement of the included couplers on each of the eighteen cars with two sets of #923505 kinematic couplers I probably wouldn’t have this problem with operating the train. The problem, though, is that Kato USA doesn’t provide the instructions on how to install the couplers on each car at their website anymore for whatever reason. Not helping matters is the fact that the pictures on how to install the couplers are also lost with the instructions. While I did manage to save the instructions to a Word document, I couldn’t save any of the pictures in time before Kato rebuilt its website. Therefore, I have decided to repost the instructions here at this forum so that anyone who is interested will finally be able to know how to install the couplers. What I would like to see in return is if anyone can provide me with pictures of each step so that myself and everyone else who is interested can be guided through the process of doing this. I feel that this will be the most practical way of dealing with this problem. To prepare, you’ll need a small flat-headed screwdriver. (NOTE: This only applies if you’ve got the 2017-onwards versions of these couplers that don’t need to be clipped off of a plastic “tree.”)
Step One: The couplers can only be installed while the car’s bodyshell is off its frame. To loosen or remove it, just grasp the car on both ends and gently twist it back and forth until the skirting and underbody pops free of the upper shell. In the case of articulated cars, you’ll need to loosen t
