I’ve just installed DCC in one of the Kato Mikados, and everything seemed to work fine with the frames loosened. However, with the frames tightened, it seems that the motor casing (metal) is shorting against the sides and end of the frame. Short of covering every possible contact area up with tape, can anyone suggest any other way I could solve this problem?
Thanks for the suggestion, but there’s already a piece of tape over that brush cap. It’s the actual motor casing that’s shorting out - it’s a ‘C’ shaped piece of bent metal with the motor inside it.
