Kato NW2 shell removal
I have a nw2 that needs service. Received shell removal instructions from Kato. How is this done without breaking the railings etc. If anyone has removed a nw2 shell PLEASE give me some tips. Thank you. [:)]
Here is a thread that discusses that very thing.
http://www.trains.com/TRC/CS/forums/348002/ShowPost.aspx
It’s been a while, but I think I tried to follow the Kato directions with no luck. I felt I would break off the steps before the shell came off. I had good success with inserting a flat screwdriver blade somewhere between the frame and shell and gently prying a little. At that point, it came off fairly easily. Once off, I saw the bumps on the frame and dents on the shell that held it together. It didn’t take much force, and the point I pried was underneath somewhere. If you can’t figure it out, I’ll take a closer look at mine.
Jim
