Hello, I am a first time poster to this site and i have been looking around for other kato related posts. I havent found any. I am wondering three things.
Is the amtrak acela and the kato double viaduct set kit compatable.
What kind of sound decoder should I use for an Amtrack acela and
Can i take out the track on one of the double viaduct peices. I wanted to replace it with a double crossover , and is that possible.
I am sort of new to this and i do not know what is compatible and what is not and i dont want to waste $500 on something that wont work together. Any tips wil be appriciated
First off, a word of wisdom is you can get an acela train set for somewhere around 200 dollars. Also, look on ebay, and you’ll find a good deal I’m sure.
The double viaduct set is compatible with most passenger trains. Some longer cars rub the edge on the single track viaduct. I’m guessing you’re thinking N-Scale. As far as the double-crossover, it would have to be custom fit to raise it to the correct height, and would not fit in a standard double track viaduct straight piece. I suppose you could kitbash something if you are feeling daring, but it goes against the easy plug-n-play design of KATO Unitrack.
You can check the KATO Unitrack discussion group at:
