Krylon matte on water based paint to protect building ?
I am just about finished painting Merchants Row V with acrylic paint and have not assembled it yet. Should I spray it with Krylon Matte Finish before going on to protect it or is spraying it a waist of time. I have done a search and could not find any info, probably not asking the right question.
Thanks for any input.
Do you plan to do any weathering with powders or pastels, in which case IIRC such weathering adheres better to a flat finish (then again, the acrylics are likely flat). Then to protect the weathering, spray with a light flat finish (yes, I find you will lose up to 50% of your weathering effect depending on the medium, so plan accordingly).
Otherwise, probably don’t need the matte overspray if everything looks flat already.
Agree with chutton’s advice.
Try a test spray or two with the Krylon. It tends to go on rapidly, so a light touch is recommended until you get the hnag of it in order to avoid runs. Despite it being more expensive, I tend to use the testors Dull-Cote for its finer, easier to control spray. Go light and Krylon will work.
I don’t plan on weathering the building, just want to protect paint if thats necessary. Will the clear coat give the building a dull gloss finish?
Thanks for the replys
It won’t be glossy. It will be dull.
If you want parts that are glossy (you don’t really want it all glossy, I assume), then mask them or paint separately. For windows, leave the glazing out until you’ve finished sparying, then install them – or mask if there’s no way to disassemble.
You are right, I don’t want glossy. I have not sprayed other buildings and was wondering if I screwed up. I was just wondering if I should have been putting a protective covering on the buildings all a long.
I only use clear flat finishes like Matte or Dull-Cote to make gloss paint into flat, or to blend in decals. I don’t believe that paint needs “protection”. You do want to let the paint dry good and hard before assembling, over night at least, a couple of days is better.
Be aware that cement wants to bond to plastic, not paint. You want to remove any paint from the bonding surfaces before assembly.
