Kwik 16mm scale question
I don’t model in this scale but I’m wondering if someone can explain the gauge used and the prototype modeled.
I’m guessing 16mm uses O gauge track (32mm).
I’m also guessing that it represents 2 feet gauge.
Last guess is that 16mm represents 16mm to the centimeter (16mm:1c). Or, does 16mm represent 1 foot?
the 16mm represents 1 foot it’s 1:19. Maybe someone from the other side of the pond will chime in about what track is used and waht it represents.
Jack
thanks, Jack,
I guess what confused me is that 16mm and “feet” are in the proportion (mixing measurements); probably b/c 16mm doesn’t work out well to inches I’m guessing
I come from a pure Metric background… I use the ratio 19.1:1 as my guide.
The most popular track for 16mm is 32mm AKA SM32 emulating a 2 foot or 600mm track.
There is also 45mm track AKA SM45 for the larger 2 feet 6inch, three feet, 750/760mm and metre gauges.
There is a very small group building what they are calling “T” gauge of 57mm for emulating CAPE gauge of 3 feet 6 inches. I have taken the easier route and I am using 63.5mm track for my CAPE gauge. Yes it is too wide -but am I bothered??? Not in the slightest!!!
regards
ralph
See I knew someone would come up with it.
Thanks Ralph.
There’s a web site to you might want to look at http://www.16mm.org.uk/
Hope that helps David.
Jack
I believe 16mm scale uses O scale standard gauge track to represent two foot gauge propotypes. The scale ratio is 1:19.1. It’s too bad this isn’t popular on this side of the pond as it is a good alternative for those who would like to model the two footers but find On30 too small and 7/8 scale too big (for most spaces). I would jump into 16mm scale in a New York Minute if only even one affordable loco was available. I’d probably use the 1:20.32 ratio as it’s much more convenient. Of course if I had a space the size of an auditorium, I’d love to do 7/8 scale.
Over ‘this’ side of the pond (the Pacific one) old light railways used a gauge of 610mm or larger, which is two foot and upwards. My railway (http://www.freewebs.com/mjhfoster/) models the two foot gauge in 1/19th scale so I use Pico SM32 (Sixteen Millimetre=one foot 32mm gauge track) 32mm gauge track.
That leaves me free to scrounge old O’ gauge track, which is 32mm too.
I recently bought a live steam loco from Regner in Germany direct. They have a US supplier too. I paid 479 Euros ($703) plus 95 Euros ($139) postage to Japan. To me this is a very reasonable price for a live steam geared loco that has water glass, pressure gauge, safety valve, gas tank, water top-up valve, lubricator all as standard. This loco is re-gaugeable from 45mm to 30mm (re-gaugeing tool supplied)
What do you think?
Regards,
Dear on30Francisco…
Where HAVE you been looking?!?!?!?! 16mm scale is the de Facto scratch builders scale(!) Yes the ready built locos are an arm and a leg -but have a look around at the kits and suppliers that are available for 16mm. I have only one 16mm loco that I have not built, and I assembled that from a kit.
Hit the home page icon on either mine or Matts entry and have a tour around the 16mm web ring.
16mm is a scale and ethos where a finely crafted steam locomotive has equal standing with a meccano clockwork powered collection of lollipop sticks pulling a wagon made from a tobacco tin using a paper clip.
My son is the very proud owner of a “Toby” and “Percy” made to run on my SM32 track -they cost me maybe £5 each to build. He now wants a “Duck” and a “Mavis” building, these are somewhat more difficult to build and I have budgeted £8 each for them…
There are NO RULES whan it comes to 16mm scale, if you like it, you build it -out of whatever junk and scrap you can find. If you examne the collection of locos found on my web page then I suppose I should explain something…
I chose the locos because no-one else had ever contemplated making them, this to my mind was very sad. They are ugly, they are articulated and they were built for work -not to be be admired!
regards
ralph
Thank you for the encouragement. I think I’ll begin by putting modified trucks on some small pieces of logging rolling stock I’ve already built for the 45mm gauge. I have to get up the nerve to regauge a cheap locomotive. I know Sierra Valley Enterprises sells their Large Scale wheelsets gauged to O scale and Aristo-Craft’s Classic trucks, besides being inexpensive, can easily be regauged to accept these wheelsets.
I modifed the “troublesome trucks” for my son from HLW kits for 45mm to 32mm by the simple means of attacking the wheel spacer with a bread knife and throwing away the coupler. The connection used is an 18p self adhesive plastic bracket used to secure curtain rods on uPVC window frames -and a paper clip…
Have look at these sites:
http://www.cambrianmodels.co.uk/16intro.html
http://www.grsuk.com/index.asp?info/welcome.htm
http://www.brandbright.co.uk/catindex.htm
http://www.ipengineering.co.uk/
You will know when the true bug has bitten when you pick up a item at the supermarket and think to yourself “that’s almost the right shape for…”
regards
ralph
