What amazed me was the distance the cars traveled
and the probable cause. I have read about runaway engines,does this happen with freight cars alot ?
Anyone with experiences on runaways ?
Hi Scott,
Here is what we were told the next day, from one of our trainmasters, so it is suspect.
Crew drags into the yard, cuts away from their train, fails to secure the cut with handbrakes, car men bleed off the air brakes, in preperation for the switch crews to go to it, and then they just started to roll.
You could stop ten to fifteen cars that were rolling slowly, if you got to them quickly enough, but once they got moving over ten mph, your smooth out of luck.
A series of mistakes, each one compounding the other, and there she goes.
If the crew yarding the train had followed the GCOR, you wouldn’t have ever read a thing.
And the grade dosnt need to be great, less than 1/2%, the cars can really roll that easy, if you know how, you can use a two by four to lever them along a level track.
What gets me is that UP didnt send the cops to clear out the folks near the sideing, unless there wasnt time, and this did seem like a last ditch, last minute effort to get them stopped.
Stay Frosty,
Ed
cars will take off all by themselves. in california its either up hill or down hill. not rolling hills. these cars just did what they was designed to do. they was bleed off and left standing probley without hand brakes applyed. and a loaded car will gain speed quickly.but what they wont do is slow down. yes cars take off on regular basis. people messing with cars get them rolling. this is why there is derails at all indusrty and spurs where cars a set out if they get rolling the fartherest they will go is on the ground.
Them cars didn’t go 40 miles without a engine pulling them. The remote control failed
Q: dont crews have two way radios to let each other know what the other is doing? seems this might not have happened if the two responsible for setting the brakes were talking to each other. The news reports said that each thought the other had set the brakes when niether did.
FYI: those cars covers about 30 miles in as many minutes. It appears that things were happening so fast the dispatchers couldnt cope with it. The latest word coming out of the UP mouthpiece’s is that the dispatchers thought the runaway was traveling slower(!) than they thought and that it wouldnt derail when it was switched to the siding. I live in LA and I can tell you I can’t drive from Commerce to Montclair in thirty minutes unless I’m doing 60-70 mph, this also contradicts what they were saying the day of the accident when UP reps said that, yes, the train was “deliberatly derailed”, they didnt say anything about “switched to a siding and accidently derailed” until this week. UP is in serious trouble with the local communities here. The feeling on the street is that they would rather wipe out a poor neighborhood than damage thier precious yard. I’m just glade no one was killed, UP would really be hung out to dry then.
The story as I read it was that the UP expected the cars to make it through that neighborhood fine even at their high speed and intended to intentionally derail them – no casual thing to do with that weight and that speed – a bit further up the line. Someone made a professional informed judgment and they were wrong. This happens every day but usually it is nothing that can be photographed or shown on TV.
I am sure wiping out people’s houses was the last thing the UP intended. But they have to accept responsibility as it was their crew that erred no matter what the error.
Dave Nelson
to many people jump to conclusions when they dont have the facts. all the reports that news people get i dont pay any attention to. those people are only guessing at what might have happened and drag it out to make it seem worse than what it is.until i get the real story its just a cut of cars that rolled down the tracks and made somebody upset.the railroad has the best saftey record in america out of all transpotation groups.
Ed, That is the same explanation that my son tells me the BNSF gave them in Spokane.
Well then, with confimation from there, it would seem like thats the most probal cause. When you work in a yard all the time, the one thing you never do is leave a cut of cars unattended, no matter what, if your going to go somewhere else, even just to the other side of the yard for another cut, you tie down what you were working on, for just that reason.
I would bet the car man started on the down hill end, and worked towards the front, thinking the road crew had tied brakes on the end they were at, and when he bled enough brakes off, there they went, and not a thing anyone could do about it.
I wouldnt want to be in anyone of the road crews shoes right about now. Or the carman who bled them off, either.
Stay Frosty,
Ed
WE DONT CARE WHAT YOU THINK!
ED
Hi Smith,
Playing devils addvocate here, but, if I was the dispatcher, and remember, they are looking at a screen with indicator lights, not a real time video monitor, and it showed this cut going like blazes towards a yard, where I know there are a bunch of LPG tankcars, or chlorine tanks, or , well, pick your posion. Choices become real limited at that point, run it into a stub ended sideing, where you know it will stop, or let it get to a yard or diamond, or into a more heavly populated area?
Now that said, I agree in part, that someone should have tied brakes on the downhill end. But, I wasnt there, so all of this is really supposition. But heres my educated guess.
Either it was a two man crew, engineer and conductor, and they knew their train was in the clear in the track they drug into, so they cut away, and tied a few brakes on the uphill side, and left, and didnt inform the carmen or yardmaster that they put the brakes on the uphill side, or it was a three man crew, again, they knew they were in the clear, and didnt want to drop off the brakeman on the way, to tie brakes on the downhill side, but instead, wanted to keep him up front, because it saved time. Either way, the rules say you should tie sufficent handbrakes on the down hill side to prevent movement. It even goes on to explain that, if needed, you can chock the wheels to prevent movement, and explains what you can use to do that.
So someone screwed the pooch, real badly.
In some of the larger yards, and on some really steep down hill grades, railroads use to have runaway tracks for just that reason, they were one ended sideings, with big mounds of dirt at the stub end, or just empty land, designed to allow a runaway to be diverted to this sideing and allowed to derail to keep it from going further down the line.
Either way, you can bet there is a crew out of service, and a lot of people at UP in hot water from the brass.
Stay Frosty,
Ed
ok, now we have something to work with. A short two sentences.
Actually the cars were supposed to have gone 70 mph in some spots and I looked at the pixs very carefully and didn’t find an engine. So what do you base your remote control theory on?
Jen
The UP is negligent, if the yard was at the top of an over 30 mile downhill grade, there should have been a derail protecting the mainline from runaways.
The crew was wrong for not putting on handbrakes. But that isn’t the only possible way a runaway can occur. I have seen the wedge that holds the drawbar in the car fall out allowing the coupler to fall on the ground. If this happened during a shove with no air there would be no way to even try to catch the cars.
Allowances for emergency circumstances must be built into a yard and the UP didn’t do that.
Even if they was on a remote control engine the engine goes into emergency when it loses a signal from the pack. the train wont go over 18mph pre-set on our packs. there is so many failsafes built into these engines this is why they dont get any work done as you haft to keep resetting these things to make them keep working.
fisrt off you dont need derails to protect main line in yards . it dont matter if the yard is at the top of mr. everest. it is stupid to do that. as trains will come in and out the thing would never be on anyways. if the drawbar comes out that is mechanical failer and nothing you could do about it anyways.but depending on which end would fall out it would derail the cut anyways ans the drawbar would dig into the ballast and stop. but instead of giving my other opinion here aout emergency circumstance built into yards tell me what you would do. then we will either commend or say why it wont work. why am i doing it this way. cause what might be obvious to you we didnt think of. and if it would work fine if it wont we will exsplain why. i am interested in this one. truthfully
another piece of my puzzle train. I didn’t realize that.
Thanx Wabash!
Jen
In addition to that - were the people at the crash site pre-warned that it was coming so they could get out of the way?
Jen
No, no warning, no notification to police or fire. This is even after two police patrol officers at a grade crossing in Puente Hills radioed in that a train with no engines (i.e. a runaway) was moving at a high rate of speed toward LA. They could have diverted the string onto another connecting track in Santa Fe Springs but they didnt react fast enough. Had they it would still have derailed but it would have been next to a riverbed with no houses around. The story coming out now is that this was there last chance to get it off the mainline before it entered the yard and before it crossed a major freeway. They also said that they had to switch it at that moment as there was a propane train in the same yard and they were fearfull of a major disaster if they collided. This is all coming from UP spokepeople. Theres still going to be a lot more info as the circumstances are examined more. City of Commerce Fire and Police only found out about the runaway after the 911 calls started flooding in. Seams UP has no emergency contigiency plans of any sort for something like this, and that a lot of mis-communication via phone and radio occurred, again this is all from UP.
Interesting, up to the last line. That seems very strange that UP wouldn’t have some kind of a plan in place for this. Unless it was in place and ignored. But we may never know, altho if I know the forum people, we will hear a lot more.
Thanx
Jen
Hi pfrench68
Derails at a yard lead or throat dont work, it s too busy there. Where I work, the yard throat is part of our switching lead, I drag out and shove back through it around 150 to 200 times a day, the derail would never be on. Besides, the other side of that would be what happens the first time someone forgets to take it off, say a foreign crew is yarding a train, and dosnt know its there? Now you have a set of locomotives on the ground blocking the entrance to your yard.
Never seen a drawbar wedge fall out, but sure it could, and have had a coupler fail on a shove, but had the crew tied sufficent brakes on the descending end, none of that would have mattered.
Bet UP does install a runaway track near this yard, thought.
Stay Frosty,
Ed
