LaBelle #106
I just opened my tube of LaBelle 106 grease with teflon and found it will not come out the spout. I punctured the opening with a 2" needle and it still appears to be too thick to come out and no trace of grease on the needle. Is this normal for this grease or do I have a bad tube? I tried to call LaBelle in Tucson Az. but they do not appear to have a web site.
Bruce,
You need to cut off the very end of the tube. Cut just the tip enough to show a clear hole. The cap threads are a long way down the nozzle so it will seal properly.
