Last Run of the Cascade Canyon Train and First Run of the Silverton, CO Train for 2018
May 4, 2018, and the weather couldn’t be more perfect for the final run to Cascade Canyon, Colorado. This train has been led by 476 for most of the season, but today 480 takes the lead. We catch the train before it departs Durango and then several more times before it leaves Rockwood. When it made an unscheduled stop at Hermosa to repair a minor pinhole leak in one of the pipes in the cab, we got some good scanner audio.
The next day, 480 leads the first train of 2018 up to Silverton. Another glorious day and this time we catch it with our drone as it arrives at it’s destination.
The 480 series or K-36 class locomotives were ten engines designed for the D&RGW. They were built by the Baldwin Locomotive Works in 1925. The 480s were the last ten narrow-gauge locomotives constructed for the D&RGW. The 480s were used for freight-hauling throughout the D&RGW 3 ft (914 mm) narrow-gauge network. The “36” stands for 36,200 lbf (161.026 kN). of tractive effort. These engines are outside frame Mikados, and all drive wheels have counterbalancing outside of the frame, resulting in the utilitarian look the engines are known for. The engines currently use 6-ET automatic air and the secondary straight air used on regular service equipment. The railroad runs 12-car passenger trains behind these engines; however more cars require the train to be doubleheaded. Despite popular belief that the railroad does not doublehead trains out of Durango because of smoke, the real reason is the weight restriction on the bridge at 15th Street, not allowing more than one K-36 at a time (K-28 class engines however are still doubleheaded from Durango). The engines were delivered with Master Mechanics design smokeboxes for draft, however at some point the D&RGW converted them to Andersson (cyclone) front ends. Water is fed to the boiler by two non-lifting injectors. The 40-square-foo
