I just got an Atlas Gold Series Trainmaster, so now I have at least one sound loco from each of the major makes - QSI, Soundtraxx, ESU, and yes, an MRC. I have both a Tsunami loco and one with an old DSD-LC decoder.
I put the following locos on the same section controlled by my PM42 power manager, you know, the one that does not work with sound decoders due to inrush current:
Atlas Trainmaster - QSI; Stewart FT-B, Tsunami; Athearn RS-3, MRC; Stewart F7-B, Soundtraxx LC, Wathers FA, TCS T-1 motor only, Stewart FT-A, TCS T-1 motor only; Stewart F7-A, TCST T-1 motor only.
All headlights on, all were making noise, none were in shutdown or muted.
I shorted the track. The PM42 started clicking. I released the short. The PM42 stopped clicking and all the sounds restarted.
That’s right, no drama, no problems, no continued short, it all worked as advertised. I’ve done NOTHING special, I don’t have ‘cheater’ light bulbs bypassing the PM42 or anything of the sort. Booster to the PM42, PM42 to the track.
As for programming, after test running the Trainmaster on 3, I picked it up and set it on my program track connected to my Zephyr. I selected Pg for paged mode programming, selected 4-digit address, keyed in 802, the cab number, pressed enter. When prompted for AD4=on? I hit the Y for yes. I then hit Exit to quit program mode, picked up the loco and moved it back to my main track. No go on address 3, selected address 802 - and off it went. So the “You can’t program QSI without a booster” - more bunk. My Tsunami programmed too, but QSI was one I haven’t had an exampe of until now, so I wanted to hit that before pronouncing all is fine. And no, I did not cheat and use Blast Mode.
