I am building my single track rise from my lower leverl to my upper level on my new HO PRR / NYC layout.
It’s not exactly a helix, but it climbs up and around so the principle and the question still applies. I’m considering sticking the track down directly on the 3/4" ply. Waht do you think? Or should I put in a roadbed such as cork or Homasote? I have 3 3/4" height clearance thru the climb (0.87%)
I personally don’t think it’s necessary apart from maybe noise reduction.
I used 1/2" plywood and Woodland Scenics Trackbed foam on mine. In 25’ rolls it goes down pretty easy. I then glued the track to the Trackbed foam and used woodclamps to hold the flextrack in place while the glue dried. I did 6’ at a time. It took a couple of days. My main reason was sound deadening and consistency with the rest of the layout. Also being a true helix, spiking the track was not an option unless the track was laid as the helix was assembled, not afterwards. Not enough room between the levels.
If noise is not a problem then on the plywood would be fine. The more room for the 0-5-0 switcher the better. We have a six turn helix at the club and one day the front coupler on the first car out of 42 car train decided to not work any more. It was not a pretty sight seeing 42 cars rocketing backwards at a scale 900 MPH. The guys in the caboose must have had one heck of a ride! Im still missing one hopper that has vanished in the helix. When I build my layout the helix will have a lot of room for hands and heads for searching. Its not fun retrieving derailed cars with a yard stick.
There is talk of dismantling the 40 year old helix and smoothing out some of the hills. Most of the layout has become unreliable after those many years. As club members get older they are not as flexible and the hidden track has become an obstacle to most.
I’d have to agree, on the plywood will work fine if sound deadening isn’t an issue. You could lay the track with latex caulk as the adhesive so you get some very minor sound deadening qualities from that.
Yes, I think I’m OK on the 3/4" ply. I’ll be using latex caulk. The only other consideration is getting the track up on roadbed once it hits the layout levels. But that’s OK, I’ll gradually chamfer in the road bed so it’s a neat and easy transition.
I was thinking that all a guy would have to do is plan to equalize the difference where layout meets helix by setting the height of 3/4" plywood to match the existing height of the roadbed on benchwork. Then again it might be easier to just shim the track to transition between the two???
Bluehills, that would work if you haven’t already built it or do mind a little reworking. Another way to go is by making a small transition ramp between the two.
I installed a double track helex in 78, I used 1/2 inch plywood, and cork roadbed. I built it in full circle segments so that I would have room to nail the roadbed and track down. I still is working with out any problems.
Over built? Well, depends, mine is not a helix. It runs around the layout and climbs up to the next level over 4 circuits. I’ve 2 uprights every 24" with the 3/4" roadbed running between them with coachbolts running thru the 3/4" ply. This gives it total rigidity and strength. But a true helix would have it’s own built in strength by it’s shape, so I’m sure 1/2" would be more than adequate.
This layout is being built as my last. I’m building it for my retirement with past experience in mind. I would much sooner have it bullet proof than flimsy. After all, after spending all that money on very expensive sound equipped trains I don’t want them crashing to the floor!
