Layout design on computer. Help!
Hi guys, I have Atlas freeware 7.0 and XTraCad on my computer. I dont know how to set my layout size and scale on etheir program. Any help would be gratefully appreciated. My layout is N scale 4x11 with a 36x32 peninsaula. Pleae help. Tim
Have you done the XtraCAD tutorial. The program walks you through the program quite well.
When you install the RTS ver. 7.0 you set which components you want to install. HO, N, O, etc.
I sent you a reply to your Email that should help with the XTrakCad.
Now for the Atlas program you can change the size of the area you’re working on by going to “View”, then “Properties”, and on the “desktop” tab at the bottom you can reset the area size. To change the trackage and scale go to “Element”, and “Load Library” to select the trackage you want to work with.
Hope this helps!
Thanks for the help guys. I will post a track plan when I am done makking it on the computer. lol Thank you again! Tim.
Chip yes I watched some of it. Thanxs
Thanxs for trying to help me with this guys but this is really annoying. I no the track plan I just wanted to show you guys my plan. Hopefully Ill be able to post pis soon. And I dont know exactly were I put the straights and cureves/turnouts. I will stick to my messy out of scale way of doing it. lol Tim
